[GRASS-dev] Critical bugs for 6.4.4 release: last chance to react, otherwise we'll release with these bugs
Sorry for the somewhat aggressive subject line, but it's meant as a heads-up and last call for action.
We want to release 6.4.4 and if no one has immediate solutions for these bugs, I suggest to just declare them as known bugs and release.
*************Executive summary**********
Of the remaining bugs marked as critical I see two where we might still need a backport to 6.4.4:
- https://trac.osgeo.org/grass/ticket/560 (WinGRASS not deleting temp ppm files from map display)
- https://trac.osgeo.org/grass/ticket/2300 (v.out.ogr: spatialite support not working)
For the rest, I think we can release with these bugs as know bugs.
More in detail;
Looking at
https://trac.osgeo.org/grass/query?status=assigned&status=new&status=reopened&group=priority&order=priority&col=id&col=summary&col=owner&col=type&col=priority&col=component&col=version&milestone=6.4.4
I see 6 critical bugs:
- https://trac.osgeo.org/grass/ticket/72 (PNG driver: boundary rendering is off by one pixel): This has been around for a long time. I'm not sure I would classify this as critical, as it is mostly about display, not analysis (AFAIU). I would vote for carrying this bug on to the next release.
- https://trac.osgeo.org/grass/ticket/335 (export floats and doubles with correct precision): I'm not sure I understand what needs to be done on this, but have the feeling that we can release with this bug.
- https://trac.osgeo.org/grass/ticket/560 (WinGRASS not deleting temp ppm files from map display): should r56444 be backported before release ?
- https://trac.osgeo.org/grass/ticket/2008 (grass.script's find_program() can't find modules): I don't know how much testing r56867 (and subsequent modifications) has received, but no one has complained since. AFAIU, the original problem of the ticket is solved, but there are different discussions happening there, so I'm a bit lost.
- https://trac.osgeo.org/grass/ticket/2087 (grass64 man page: missing words): I've closed this as there have been no objections to the fix.
- https://trac.osgeo.org/grass/ticket/2300 (v.out.ogr: spatialite support not working): Hamish proposes a patch which he tested against grass6devel. This sound sufficiently critical to me to warrant a backport.
Looking through the bugs classified as major, most are nuisances, but not really critical. Possible exceptions:
- https://trac.osgeo.org/grass/ticket/2016 (v.surf.idw: very incorrect results)
- https://trac.osgeo.org/grass/ticket/1500 (g.region returns wrong convergence angle), but this seems to concern only specific environments
- https://trac.osgeo.org/grass/ticket/2081 (r.sun (mode 2): sawtooth bug in diffuse irradiation map)
Moritz
On Tue, Jun 24, 2014 at 5:03 AM, Moritz Lennert <
I just committed a fix for it to 6.5, should I go ahead and backport it now?
not working)
More in detail;
Looking at
milestone=6.4.4
results)
Moritz
grass-dev mailing list
grass-dev@lists.osgeo.org
2014-06-24 19:59 GMT+02:00 Anna Petrášová <kratochanna@gmail.com>:
I think that it's going in the direction that you don't need to hurry
with backports. AFAIK Markus is going to be offline in two days for
some time (he noted that already). Deadline for OSGeo Live is July 6.
History repeats, we are close to fail to release again in time. These
two requests for backports means that we simply miss OSGeo Live, seems
to me.
Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
2014-06-24 11:03 GMT+02:00 Moritz Lennert <mlennert@club.worldonline.be>:
I can imagine more aggressive subject;-) in other worlds thanks for
raising this issue...
not working)
If we want to pass deadline for OSGeo Live we have only one choice,
release it as it is. Martin
On Tue, Jun 24, 2014 at 11:47 PM, Martin Landa <landa.martin@gmail.com> wrote:
... which is pretty fine!
My 0.02 cents,
2014-06-24 23:48 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
also for me! I think it's better to have in OSGeo Live GRASS 6.4.4
rather that 6.4.3.
Martin
2014-06-24 23:51 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
rather that 6.4.3.
in other votes let us know if you have any objections. If not, we can
release on Wed/Thu this week.
Martin
Dear Anna,
if you tested *well* (otherwise let's keep it for 6.4.5), please
backport, than we can try tomorrows build of GRASS 6.4 (build process
starts on the server at 3am CET). Martin
On Tue, Jun 24, 2014 at 5:56 PM, Martin Landa <landa.martin@gmail.com>
wrote:
Dear Anna,
ppm
now?
Sorry for getting to it so late. Although I think the change is pretty
safe, it's not 100% safe, so let's wait for next release.
On Tue, Jun 24, 2014 at 5:52 PM, Martin Landa <landa.martin@gmail.com>
> rather that 6.4.3.
+1
Martin
Sorry for getting to it so late. Although I think the change is pretty safe,
Thanks for spending time/energy on that! Martin
2014-06-24 23:52 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
s/votes/words/g :wink:
Although I do adhere more to the principle of release when ready, not when some outside event forces you, I would say go ahead for release. The remaining issues should be clearly noted as known bugs, but I agree that they are not _that_ critical and that in the whole, 6.4.4 is much nicer than 6.4.3...
Moritz
2014-06-25 10:22 GMT+02:00 Moritz Lennert <mlennert@club.worldonline.be>:
6.4.3...
I have tested last build no. 1002 on Windows too (both standalone and
osgeo4w). Let's go ahead...
Martin
On Wed, Jun 25, 2014 at 11:58 AM, Martin Landa <landa.martin@gmail.com> wrote:
6.4.3...
I'm ready to go today.
Hi devs,
I am going to tag 6.4.4 now.
2014-06-25 17:48 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
I put online winGRASS (both standalone [1] and OSGeo4W [2])
installers. Currently only 32bit, OSGeo4W 64bit still contains 6.4.3.
It will hopefully change soon.
Testing welcome, Martin
[1] http://grass.osgeo.org/grass64/binary/mswindows/native/WinGRASS-6.4.4-1-Setup.exe
[2] http://trac.osgeo.org/osgeo4w/wiki/PackageListing#a6.4.4stable
