[GRASS-dev] cruft in SVN
$ svn update
D raster/r.li/r.li.daemon/main.c
A raster/r.li/r.li.daemon/main.c.unused
If a file isn't needed, just remove it. It can always be retrieved
from the repository if a need is subsequently found.
On Wed, May 28, 2008 at 5:31 PM, Glynn Clements
<glynn@gclements.plus.com> wrote:
$ svn update
I dunno if not needed... I just discovered that it isn't compiled.
right.
Removed from trunk.
