[GRASS-dev] ctypes mystery
when developing wxNviz I am facing to the strange problem with ctypes.
Nviz_get_exag_height() [1] returns correct values.
D1/1: Nviz_get_exag_height(): value = 805.696899 min = -2944.302979
max = 4555.696777
SetViewDefault() [2] which is calling Nviz_get_exag_height() gets
incorrect values.
GUI D1/1: Nviz::SetViewDefault(): hdef=2.000000, hmin=0.000000,
hmax=36893488147419103232.000000
Any idea what can be wrong?
Thanks, Martin
[1] http://trac.osgeo.org/grass/browser/grass/trunk/lib/nviz/exag.c#L63
[2] http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/gui_modules/wxnviz.py#L95
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Martin Landa wrote:
max = 4555.696777
incorrect values.
Thanks, Martin
Just a wild guess, try in wxnviz.py c_double() instead of c_float()
because Nviz_get_exag_height() wants double pointers, not float
pointers (confusing: python doc says python float = C double).
BTW, I get a number of compile errors in
trunk/gui/wxpython/nviz/change_view.cpp about type conversions. In
nviz.h, one error about too many arguments:
include/grass/nviz.h:134: error: too many arguments to function ‘int
Nviz_set_viewpoint_twist(int)’
No changes in my local copy, updated 1 hour ago.
Maybe this is pointing into the right direction,
Markus M
2010/6/23 Markus Metz <markus.metz.giswork@googlemail.com>:
ops, right. I completely overlook this issue. Thanks for pointing this out.
C++ nviz component is not used in trunk (replaced by wxnviz.py). I
would suggest to remove it if there are no objections. Another issue
is to backport ctypes interface to devbr6.
Martin
