[GRASS-dev] Current state of GUIs on Win32
Benjamin,
A couple of responses. See below
Michael
On Mar 7, 2008, at 10:00 AM, grass-dev-request@lists.osgeo.org wrote:
Date: Fri, 07 Mar 2008 16:13:03 +0000
From: Benjamin Ducke <benjamin.ducke@ufg.uni-kiel.de>
Subject: [GRASS-dev] Current state of GUIs on Win32
To: GRASS devel <grass-dev@grass.itc.it>
Message-ID: <47D1698F.6040109@ufg.uni-kiel.de>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
(not sure, but my last email seems to have disappeared somehow,
so here goes another try).
I have been trying the current versions of the GUIs (Tcl/Tk and
WxWidgets) using GRASS 6.3.rc5 on Win32 (MinGW/MSYS Build).
They all have a number of issues that make them less than a
pleasant experience for Windows users right now:
1. Tcl/Tk
Version 8.5.1 (GPL) works fine, NVIZ starts up, can visualize 3D DEM.
Hangs when trying to add a vector points map.
Tk 8.5.1 has new widgets that are closer to the Win native ones.
NVIZ uses those, but the module forms and gis.m don't, resulting in
a strange look and feel.
The current GUI is based on TclTk 8.4.14 or so. As some people have noted, it may work with 8.5, but there is no guarantee about it. Given that we are replacing this GUI, I don't think it is worth the effort to update the GUI to 8.5.
2. WxPython
I installed Python 2.5 and WxPython 2.8. I found that I also had to
install the Python Extensions for Windows from here:
  http://sourceforge.net/project/showfiles.php?group_id=78018
Doing grass63 -wxpython then gave me:
AFAIK, the error reported below was fixed in the svn trunk a week or so back. I saw a note from Martin to that effect. Please let us know if that is not the case.
Michael
Starting GRASS ...
  File "C:/msys/1.0/local/grass-6.3.0RC5/etc/wxpython/gis_set.py", line
690, in <module>
    GRASSStartUp = StartUp(0)
  File
"C:\msys\1.0\local\python\Lib\site-packages\wx-2.8-msw-unicode\wx\_core.py",
line 7836, in __init__
    self._BootstrapApp()
  File
line 7433, in _BootstrapApp
    return _core_.PyApp__BootstrapApp(*args, **kwargs)
674, in OnInit
    StartUp = GRASSStartup()
45, in __init__
    self.grassrc = self._read_grassrc()
356, in _read_grassrc
    key, val = line.split(":")
ValueError: too many values to unpack
Error in GUI startup. If necessary, please
report this error to the GRASS developers.
Switching to text mode now.
Hit RETURN to continue...
According to some Python forums:
The "too many values to unpack" indicates you don't have enough
variables in the [for (...) in <var>: ] construct.
... so is the WxPython GUI broken in RC5?
Anybody had better luck with WxPython on Win yet?
Benjamin
Benjamin Ducke
Senior Applications Support and Development Officer
Oxford Archaeological Unit Limited
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel.: ++44 (0)1865 263 800
benjamin.ducke@oxfordarch.co.uk
IMO we should at least attempt to support Tcl/Tk 8.3 - 8.5.
For 8.3 there is just the one problem with v.digit, AFAIK.
For 8.5 it apparently mostly works, if it is just a few little issues
which are not so hard to fix, then we should try and solve them.
i.e. we should at least look into 8.5 problems, it is probably just 1-5
lines of code to be adjusted, and that's not a huge drain on
development resources.
Hamish
      ____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
