[GRASS-dev] Current state of wxPython GUI
FWIW, some observations on the wxPython GUI, running on a Ubuntu (7.10)
box with an SVN checkout from 10 minutes ago:
1. Starting "from" scratch, i.e. with no prior GRASS login and
no .grassrc6 file present, the wx GUI intro screen is dysfunctional.
It does not let you specify any mapsets in a GRASS DB directory.
The error message is:
    "Error in command execution g.mapset"
    Execution failed: 'g.mapset -l location=borkeld
    gisdbase=/home/benni/grass-db'
    Details:
    (empty)
I get this error when first browsing to the "GIS Data Directory" (not
sure this is a good name, as it seems very generic) and then selecting
any location name.
If I first start with the old Tcl/Tk GUI, then select a mapset there,
then logout and start with the wx GUI, things work fine.
2. Both wxGUI and the old gis.m crash on startup if the location does
not have any valid projection information. Is that really necessary?
3. Dragging any toolbars in the "Map Display" window of the wxpython GUI
makes it crash.
4. When starting with an empty "Layer Manager": after adding the first
layer (vector in my case), the "Map Display" does not draw anything when
clicking on the "Display map" icon. I need to click on "Re-render map".
This seems counter-intuitive to me.
... well, hope this will help smoothing out the wxpython GUI, as it sure
starts looking good!
Best,
Benjamin
On 27/03/08 13:28, benjamin.ducke@ufg.uni-kiel.de wrote:
If it is of any help: I can confirm all of those.
Moritz
    Details:
    (empty)
any location name.
makes it crash.
Best,
Benjamin
grass-dev mailing list
grass-dev@lists.osgeo.org
2008/3/27, benjamin.ducke@ufg.uni-kiel.de <benjamin.ducke@ufg.uni-kiel.de>:
    Details:
    (empty)
any location name.
this should be fixed in trunk now [1] (this bug has been introduced
recently, it is not affecting releasebranch_6_3 at all). Can you
confirm it?
Any GRASS location should have valid information about projection.
Anyway it is not reason for crashing GUI. I will take a look.
makes it crash.
It can be issue of wxPython version you are using.
Just enable auto-rendering (right-most checkbox in the map display statusbar).
Martin
[1] http://trac.osgeo.org/grass/changeset/30759
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
2008/3/27, Martin Landa <landa.martin@gmail.com>:
Martin:
sorry, I didn't read carefully. "Display Map" should behave like
"Re-render map" when you add/remove/change map layer.
TODO
Martin
