[GRASS-dev] Current state of wxPython GUI
IndexError: list index out of range
should be also fixed in trunk now
OK, that works now.
2. The GRASS init shell script now dumps this message twice to the
console:
"To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details."
I guess it attempts to run something with su privileges?
OK, I assume this is well-known 'sudo' behaviour issue on Ubuntu...
I am only getting second thoughts that this means some important
commands are not being run upon start-up on Ubuntu.
Do you know which commands might cause these messages so I can look
into it?
Best,
Benjamin
Martin
