I wanted to backport the v.dissolve column support to the
6.2 release branch, but
bartok:v.dissolve[3553.44] cvs ci -m"backported col support"
cvs commit: Examining .
cvs server: sticky tag `releasebranch_6_2' for file `description.html' is not a branch
cvs server: sticky tag `releasebranch_6_2' for file `v.dissolve' is not a branch
cvs [server aborted]: correct above errors first!
bartok:v.dissolve[3554.45] cvs tag -b -r releasebranch_6_2 releasebranch_6_2
cvs server: Tagging .
W Makefile : releasebranch_6_2 already exists on version 1.1 : NOT MOVING tag to branch 1.1.0.2
W description.html : releasebranch_6_2 already exists on version 1.1 : NOT MOVING tag to branch 1.1.0.2
W v.dissolve : releasebranch_6_2 already exists on version 1.1 : NOT MOVING tag to branch 1.1.0.2
but the problem persists. Suggestions welcome. AFAIR the v.dissolve
was added later to the branch (and hence the mess).
is not a branch cvs server: sticky tag `releasebranch_6_2' for file
`v.dissolve' is not a branch cvs [server aborted]: correct above
errors first!
releasebranch_6_2 cvs server: Tagging .
MOVING tag to branch 1.1.0.2 W description.html : releasebranch_6_2
already exists on version 1.1 : NOT MOVING tag to branch 1.1.0.2 W
Yes. Apparently I added v.dissolve and v.centroids to releasebranch_6_2
as a tag and not a branch. I'm not sure how to fix that.
