I have added a new C module in the addons svn which will draw wind barbs,
straw plots, and arrow plots from a raster array or sparse vector point
data. It can use either direction + magnitude, or u + v components as the
input, and can produce a legend key.
Some of this functionality is already covered by d.rast.arrow and d.vect,
but I thought I'd bring it together into a dedicated tool and add some
commonly needed options.
It's still a work in progress, and there are still a few things on the
todo list, but I think it's ready to get some testing now.
Once the bugs are out and the design & feature set have been finalized
I'd port it to grass7 and hope to add it to the main distribution + GUI.
(One weird thing I notice is that in the tcl/tk GUI the legend_at=
option appears as a tick box not a text entry field. ?)
http://grass.osgeo.org/wiki/GRASS_AddOns#d.barb
http://trac.osgeo.org/grass/browser/grass-addons/display/d.barb
screenshot: (style=arrow)
http://bambi.otago.ac.nz/hamish/grass/screenshots/narr-a_221_20100629_1800_000_10m_winds.png
maybe g.extension works to install it if you compiled grass yourself?
(I haven't tried installing it that way yet)
comments, wishes, & criticisms welcome. usage follows, see the help
page for more explanation & examples.
Hamish
GRASS65> d.barb --help
Description:
Draws flow barbs.
Keywords:
Usage:
d.barb [-r] [direction=name] [magnitude=name] [u=name] [v=name]
[input=name] [layer=value] [style=string] [color=name] [skip=value]
[scale=value] [peak=value] [aspect_type=string]
[legend_at=x,y[,x,y,...]] [legend_velo=value[,value,...]]
[legend_fontsize=value] [--verbose] [--quiet]
Flags:
-r Rotate direction 180 degrees
Useful for switching between atmospheric and oceanographic conventions
--v Verbose module output
--q Quiet module output
Parameters:
direction Raster map (or attribute column) containing velocity direction
magnitude Raster map (or attribute column) containing velocity magnitude
u Raster map (or attribute column) containing u-component of velocity
v Raster map (or attribute column) containing v-component of velocity
input Name of input vector map
layer Layer number
A single vector map can be connected to multiple database tables. This number determines which table to use.
default: 1
style Style
options: arrow,barb,straw
default: arrow
color Color
Either a standard color name or R:G:B triplet
default: black
skip Draw arrow every Nth grid cell
default: 10
scale Scale factor for arrow rendering
default: 1.0
peak Maximum value for scaling (overrides map's maximum)
aspect_type Direction map aspect type
options: cartesian,compass
default: cartesian
legend_at Screen percentage for legend barb ([0,0] is bottom-left)
Draws a single barb and exits
options: 0-100
default: 10.0,10.0
legend_velo Velocity for legend key arrow
legend_fontsize Font size used in legend
default: 14
