[GRASS-dev] d.his vs. r.his
I am trying to recreate the 'd.his brighten=' effect with r.his, but with r.his along with the brightness I get extremely high contrast output.
e.g.
#spearfish d.out.file help page example
r.shaded.relief map=elevation.dem shad=elev.shad_relf
r.mapcalc "elev.shad_relf_bright50 = elev.shad_relf * 1.5"
r.his h=elevation.dem i=elev.shad_relf_bright50 r=esr.r g=esr.g b=esr.b
d.rgb r=esr.r g=esr.g b=esr.b
# versus
d.his h=elevation.dem i=elev.shad_relf brighten=50
thanks,
Hamish
output.
e.g.
$ r.info -r elev.shad_relf
min=-19.392856
max=95.629158
# versus
You're forgetting the colour tables. Twice.
First, r.mapcalc needs to use the intensities for elev.shad_relf, not
its values.
Second, r.his uses the intensities for elev.shad_relf_bright50, not
its values. As you aren't setting a colour table, you get the default
rainbow colours.
Try this instead:
  r.mapcalc 'elev.shad_relf_bright50 = #elev.shad_relf * 1.5'
  r.colors elev.shad_relf_bright50 color=grey255
It gives results similar to d.his.
> output.
Glynn:
its values.
rainbow colours.
Try this instead:
Yes, right, thanks. I think I need to read a book on advanced color theory
someday.
Hamish
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
