[GRASS-dev] d.linegraph: secondary_width parameter defined as integer but default value is a float
Dear dev,
I’ve noticed that the module d.linegraph define the secondary_width parameter as follow:
/* theoretically for other things than points */
secondary_width_opt = G_define_option();
secondary_width_opt->key = "secondary_width";
secondary_width_opt->description = _("Width of point symbol lines");
secondary_width_opt->type = TYPE_INTEGER;
secondary_width_opt->required = NO;
secondary_width_opt->multiple = YES;
secondary_width_opt->answer = "0.1";
So the parameter type is supposed to be an integer, but the default value it is a float?
Is it intentional and in case why?
All the best
Pietro
On Fri, Mar 23, 2018 at 11:54 PM, Pietro <peter.zamb@gmail.com> wrote:
Dear dev,
I've noticed that the module d.linegraph define the secondary_width
is a float?
It came in through r69694. Probably simply an oversight?
ciao
> Dear dev,
value it
> is a float?
secondary_width_opt is used to set symbol_line_width which is of type
double, the conversion is done with atof(), and symbol_line_width is used
for D_line_width() which takes double, so no, it is not intentional. Fixed
in r72558, backported to 7.4 in 72559.
https://trac.osgeo.org/grass/browser/grass/trunk/display/d.linegraph/main.c
https://trac.osgeo.org/grass/changeset/69694
https://grass.osgeo.org/programming7/draw2_8c.html#a7d7fc5729a6e6d14ad6403ed53466414
https://trac.osgeo.org/grass/changeset/72558
