[GRASS-dev] d.mon crashes in current 6.3 CVS
On 2 32bit and 1 64bit different machines (but all Ubuntu Dapper) d.mon
segfaults for me as follows:
$ d.mon x0
using default visual which is TrueColor
ncolors: 16777216
Segmentation fault
Segmentation fault
Problem selecting x0. Will try once more
Segmentation fault
Monitor pops up for a short while and dissapears.
I can't get obtain a backtrace. Gdb only says: "Program exited with
code 01."
Can anybody reproduce?
Maciek
$ d.mon x0
ncolors: 16777216
Segmentation fault
Segmentation fault
Segmentation fault
code 01."
Yes:
#1 0xb7efdccb in _get_make_sock_path () at unix_socks.c:101
101 len = strlen(prefix) + strlen(user) + strlen(GRASS_VERSION_MAJOR) + strlen(GRASS_VERSION_MINOR) + strlen(lock) + 3;
Fixed in CVS:
--- lib/gis/unix_socks.c 10 Apr 2007 19:00:39 -0000 1.12
+++ lib/gis/unix_socks.c 26 Apr 2007 22:43:30 -0000
@@ -98,7 +98,7 @@
     if ( (lock = getenv ( "GIS_LOCK" )) == NULL )
   G_fatal_error ("Cannot get GIS_LOCK enviroment variable value");
- len = strlen(prefix) + strlen(user) + strlen(GRASS_VERSION_MAJOR) + strlen(GRASS_VERSION_MINOR) + strlen(lock) + 3;
+ len = strlen(prefix) + strlen(user) + strlen(lock) + 3;
     path = G_malloc (len);
     sprintf (path, "%s-%s-%s", prefix, user, lock);
Glynn Clements wrote:
Fixed in CVS:
Thank you Glynn!
Maciek
