[GRASS-dev] d.mon/d.rast from within python script gives empty monitor
Dear devs,
I am trying to generate maps as part of a python script. Running the following directly on the python command (python tab in main gui) works.
import grass.script as gs
gs.run_command("d.mon", start="wx1")
gs.run_command("d.rast", map="mymap")
However, when running the same from a python scrip (e.g., using the GRASS Simple Python Editor) results in an empty monitor. Any idea what I am doing wrong (or is this a bug)?
Rgds,
Paulo
2017-03-04 12:17 GMT+01:00 Paulo van Breugel <p.vanbreugel@gmail.com>:
try to add with reasonable number of seconds
time.sleep(...)
It should help. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On 04-03-17 18:36, Martin Landa wrote:
time.sleep(...)
Yes, it did, thanks Martin. Out of curiosity, why is this needed (unlike when running from the command line)?
