when I try to render raster and vector layer into PNG file in grass7
with d.mon, only the last layer is visible - I can see only the
vector.
I use this code in python script:
os.environ['GRASS_TRANSPARENT'] = "TRUE"
grass.run_command('d.mon', start='png', output = "testFile.png",
width = 640, height = 480, overwrite = True)
grass.run_command('d.rast', map = 'elevation')
grass.run_command('d.vect', map = 'roadsmajor', color = 'red')
grass.run_command('d.mon', stop = 'png')
Do I miss something or it's a bug?
Anna
2012/7/10 Anna Kratochvílová <kratochanna@gmail.com>:
vector.
probably missing GRASS_PNG_READ env variable, please try r52358.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
On Tue, Jul 10, 2012 at 9:58 AM, Martin Landa <landa.martin@gmail.com> wrote:
vector.
Thanks a lot, it works now
Anna
Martin
