[GRASS-dev] d.mon segfaulting on debian/ubuntu custom/docker
running
d.mon start=cairo
d.mon stop=cairo
will lead to Segmentation fault.
same for
d.mon start=wx0
or
d.mon start=png
I'm using GRASS 7.8.2, official packages from Ubuntu 20.04, nothing fancy.
When tried docker image
docker run --rm -ti -v $(pwd):/data/ -v $(pwd)/grassdata:/grassdata
mundialis/grass-py3-pdal:stable-ubuntu
it was segfaulting too! so was debian
when trying -alpine , no problem (or did not seem to be)
Any hint, what could be the reason?
Jachym
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
Il mar 4 mag 2021, 20:30 Jachym Cepicky <jachym.cepicky@gmail.com> ha scritto:
Hi Jackym
running
d.mon start=cairo
d.mon stop=cairo
same for
d.mon start=wx0
or
d.mon start=png
I’m using GRASS 7.8.2, official packages from Ubuntu 20.04, nothing fancy.
No idea, just a silly question…
Did you try rendering any maps?
With cairo I usually set the output variable…
I’m using “d.mon start=cairo out=/path/to/file” daily and I have no problem.
Jachym
Ciao
Luca
On Tue, May 4, 2021 at 8:30 PM Jachym Cepicky <jachym.cepicky@gmail.com> wrote:
running
d.mon start=cairo
d.mon stop=cairo
I have tried that
docker run -it --rm docker.io/library/ubuntu
apt-get update
apt-get install grass
grass -c epsg:25832 grassdata/gb
Welcome to GRASS GIS 7.8.2
GRASS 7.8.2 (gb):\w > d.mon start=cairo
Output file: /root/map.png
ERROR: option <output>: <map.png> exists. To overwrite, use the --overwrite
       flag
GRASS 7.8.2 (gb):\w > d.mon start=cairo --o
WARNING: File <map.png> already exists and will be overwritten
GRASS 7.8.2 (gb):\w > d.mon stop=cairo
Works all fine...
