[GRASS-dev] d.rast.edit: can't remove some temp files
The tcl/tk d.rast.edit in current 6.3 CVS prints following info to the
output after "Exit":
Raster map <tmp.d.rast.edit> not found
<tmp.d.rast.edit> nothing removed
Is that OK?
Maciek
Is that OK?
Yes. It always removes the temporary map on exit, regardless of
whether or not it used it.
