Paul Kelly wrote:
I tried running it on Windows - looks neat enough. A few comments:
Couldn't get it running directly: as far as I can see the
exec "$GRASS_WISH" "$0" "$@" syntax is having problems with confused
Msys/Windows paths or something. Hard to get to the bottom of.
Hmm. I could add a front-end shell script which does the g.parser
stuff then explicitly invokes $GRASS_WISH on the Tcl script.
But running g.parser directly on the script file works OK. I came across
the problem with r.out.ppm always returning an error code but I see you've
already fixed that in CVS. Does that mean nobody had ever tried running
it from Tcl before?
I presume so.
The 2>@stderr syntax doesn't work on Windows and when I changed it to
2>NUL: everything ran OK.
Noticed a bug: can only save the output map once - the second and
subsequent times I get a broken pipe error - caused by error message from
r.in.ascii about over-writing the file - possibly call it with --overwrite
option? I guess if there was a pre-existing map it will have been checked
at the time the script was started, so d.rast.edit will only be
over-writing what it itself created.
I originally figured that if you run the d.rast.edit script with --o,
it would set GRASS_OVERWRITE, and if you didn't use --o, you would
want overwrite to fail. I didn't allow for saving it twice.
I'll change it to explicitly use --o when calling r.in.ascii.
Also it would be good if there was some way it could determine if the
region was too large and abandon startup instead of using up lots of
memory and taking a long time to do nothing. Maybe you could calculate
something from the width of the black lines between the cells and the size
of the canvas in pixels, and determine when there would be so many cells
that the lines between them would merge together, and refuse to run then?
I suppose you would need to provide an option then for people with huge
monitors and high-spec PCs - maybe it could read the initial screen size
from the environment variables for the monitor size or something.
The cells will never be any smaller than 12x12; it will enlarge the
view if necessary (hence the scrollbars). However, it might take a
long time to start up if you have a lot of cells.
FWIW, spearfish at 100m resolution (190x143 = 27170 cells) takes 7
seconds to start up on a P3/800. I would expect it to take over a
minute at the default 30m resolution (634x477 = 302418 cells).
Obviously, using it on high-resolution data isn't going to be
practical.
Choosing a "sane" limit is hard, given the range of hardware.
Ultimately, the user can always kill it with Ctrl-C if it takes too
long. It might be worth adding a progress bar to give the user some
advance warning.
Also: title bar currently says d.rast, not d.rast.edit.
Presumably, the Windows Tcl/Tk treats ".edit" as the executable's
extension and omits it as it would ".exe".
I'll add a "wm title ...".
I'll also replace the hard-coded canvas width/height and cell size
with options.
