I am dealing with hourly Microwave data that are not covering the
whole World in each layer.
To have a decent presentation map of the data, I'd like to get a set
(say 30-50 layers) displayed in one go.
OK I could do it with the png driver in a script (which is what it may
eventually become), but for the sake of knowledge, is there a GUI
option to load a (rather large) set of images in one block without
having to struggle with a cluttered GIS Manager?
On 19 March 2013 09:31, Yann Chemin <yann.chemin@gmail.com> wrote:
OK found Ctrl+Shift+L in wxGUI
Yes, it is my favorite feature. I use it even to find and add one map.
However, there is some issue with many layers in layer manager. If you
load more than 20 (?) layers (maps) only some of them will be
rendered. There were no investigations; maybe it applies only to
vectors. And, of course, it is slow.
Thanks !
Yann
Yann,
If I have a large number of layers, I usually do it from a command line or with a script. I done r.patch with over 100 layers in one command ( before I discovered gdalbuildvirt :-))
To have a decent presentation map of the data, I’d like to get a set
The opinions I express are my own and are not representative of the official policy of the U.S.Fish and Wildlife Service or Dept. of the Interior. Life is too short for undocumented, proprietary data formats.
yes r.patch is a good alternative, but it means writing to disk etc.
Was more thinking of a display memory thingy.
Been thinking about the virtual rasters indeed, maybe will have a
look, any C code page you could direct me to?
Yann
On 20 March 2013 05:39, Newcomb, Doug <doug_newcomb@fws.gov> wrote:
Yann,
Doug
> Thanks !
> Yann
>> Thanks
>> Yann
>> Yann Chemin
>> Researcher@IWMI
>> Skype/FB: yann.chemin
> Yann Chemin
> Researcher@IWMI
> grass-dev mailing list
> grass-dev@lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
grass-dev@lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/grass-dev
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb@fws.gov
Yann,
On Tue, Mar 19, 2013 at 10:01 PM, Yann Chemin <yann.chemin@gmail.com> wrote:
Thank you Doug,
Yann
> Yann,
> or
> before
> Doug
>> > Thanks !
>> > Yann
>> >> may
>> >> Thanks
>> >> Yann
>> >> Yann Chemin
>> >> Researcher@IWMI
>> > Yann Chemin
>> > Researcher@IWMI
>> > _______________________________________________
> Doug Newcomb
> USFWS
> Raleigh, NC
> official
> Life
Doug Newcomb
USFWS
Raleigh, NC
