Do you want me to explicitly add @mapset for selecting items in the current
maset (already the case for items chosen from other mapsets) in
select.Select?
Michael
On 3/23/07 1:47 AM, "Jachym Cepicky" <jachym.cepicky@gmail.com> wrote:
Hi Michael,
I agree, the warnings are feature and not a bug. We shoudl
always
specify mapset, otherwise it could happen, that the user wilå
operate
with other map, than desired..
jachym
2007/3/23, Michael Barton
<michael.barton@asu.edu>:
OK. I understand your and Hamish's points. It just
seems I'm being warned
that I'm doing what I intended to do. But others may
do the same thing
unintentionally, hence the warning.
Michael
On
3/22/07 10:06 PM, "Glynn Clements" <glynn@gclements.plus.com> wrote:
Michael Barton wrote:
>>>> d.rast is still noisy, even with the quiet
flag. Can we turn this
>>>> stuff off somehow?
>>>> d.rast
agro_soils --q
>>>> WARNING: 'cell/agro_soils' was found in more mapsets
(also found in
>>>> user1).
>>>> WARNING: using 'agro_soils@PERMANENT'.
>>> WARNINGs are not affected by verbosity controls. The above warning
is
>>> there for a reason, as you have requested an ambiguous action.
>> This is not an ambiguous action.
> Only in the sense that,
ultimately, all actions are unambiguous,
> insofar as that they have a
concrete end result.
> OTOH, the action may well have non-obvious
consequences, which is
> probably a more useful classification than whether
or not it is
> ambiguous.
>> I'm picking the version of the file in
the
>> current mapset. For that, it is unnecessary to specify the mapset.
> Incorrect.
> If you want the version which comes first in the
mapset search path,
> then it's unnecessary to specify the mapset. The
current mapset
> doesn't have to be the first one in the search path; that's
just the
> default if you don't specify an explicit search path.
>> So
what if there is another file with the same name in another
>> mapset?
> That file may well have been the one which you intended to use.
>> I
may have 10
>> files with that name in different places. What does this
matter. If I want
>> to pick any file outside the current mapset, I should
specify it.
> You are free to set an explicit search path containing
only the
> current mapset (and not PERMANENT), but that isn't the default.
The
> default is the current mapset followed by PERMANENT. If you set a
search path which only contains one mapset (e.g. the current mapset),
> you
will never get more than one match for an unqualified name, and
> thus will
never see the warning.
School of Human Evolution & Social
Change
Arizona State
University
phone: 480-965-6213
fax: 480-965-7671
www:
http://www.public.asu.edu/~cmbarton
grassgui mailing list
grassgui@grass.itc.it
http://grass.itc.it/mailman/listinfo/grassgui
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG:
http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
