Glynn Clements wrote:
Hamish wrote:
> currently d.redraw doesn't use the parser as it takes no options.
> For man pages, etc it is nice to use it.
> There is --ui to force the GUI in parser.c, but no --no-ui to avoid
> it. And no enviro vars to control this either, AFAICT.
What would --no-ui achieve?
the same as GRASS_UI_TERM=1
The GUI dialog should only be generated if you don't pass any
arguments but the program has at least one required argument.
However, currently it's up to the module to implement this. Modules
which can be run without arguments should skip calling G_parser() if
no arguments are given, e.g.:
if (argc > 1 && G_parser(argc, argv))
exit(1);
If necessary, this could be added to G_parser(); relying upon the
module to do it saves G_parser() from having to determine whether
there are any required arguments.
Apart from that, the only use for a --no-ui switch which I can see is
to force an error message (rather than a dialog) when one or more
arguments are required but none are given.
Or am I missing something?
I am talking about shell scripts that normally take no arguments:
d.redraw (GUI + [Run] is not desired)
v.build.all, v.convert.all, v.in.sites.all
(GUI+[Run] would be ok IF --ui was given [but must function without tcltk])
for the last three, --q is probably a good idea.
right now they bypass g.parser most of the time:
if [ $# -eq 0 ] || [ $1 = "-h" -o $1 = "help" -o $1 = "-help" -o $1 = "--help" ] ; then
if [ "$1" != "@ARGS_PARSED@" ] ; then
exec g.parser "$0" "$@"
fi
fi
We could add '-o $1 = "--html-description"', xml, tcl, ui, --q, --v, to
that list, but it seems a bad solution. Removing that line and running
with no args,
G63> GRASS_UI_TERM=1 d.redraw
Programmer error: no flags or options
> Any problem with adding the --q flag to get the same effect?
--q is for the user. If the user doesn't use --q, they presumably want
their normal verbosity settings to be honoured.
> -#GUI is not very useful here, commented:
> -#if [ "$1" != "@ARGS_PARSED@" ] ; then
> -# exec g.parser "$0" "$@"
> -#fi
> +#GUI is not very useful here,
> +if [ "$1" != "@ARGS_PARSED@" ] ; then
> + exec g.parser "$0" "$@" --q
> +fi
If you want an error message instead of a GUI when no arguments are
given, you could use:
if [ "$#" = 0 ] ; then
else
fi
fi
I want the modules to run when no args are passed, but use G_parser()
otherwise. so maybe just:
if [ "$#" -gt 0 ] ; then
fi
what's contained in "@ARGS_PARSED@"?
Hamish
