[GRASS-dev] d.region
hi,
I created new script, absed on d.region.box from Hamish. It has few
more options.
I think, script like this should go to GRASS (and not to live only as addon)
I called it d.region, here is it's help:
Description:
Draw desired region into current display
Keywords:
display, region
Usage:
d.region [-dcf] [name=string] [color=string] [width=value]
   [rast=string] [rast3d=string] [vect=string] [3dview=string] [n=value]
   [s=value] [e=value] [w=value] [--verbose] [--quiet]
Flags:
  -d Draw default region
  -c Draw current region
  -f Non-persistant box (doesn't survive redraw or zoom)
--v Verbose module output
--q Quiet module output
Parameters:
    name Region name
   color Color to draw with, either a standard GRASS color or R:G:B triplet
           default: black
   width Line width
           default: 1
    rast Draw region to match this raster map
  rast3d Draw region to match this 3D raster map
    vect Draw region to match this vector map
  3dview Draw region to match this 3dview file
       n Value for the northern edge
       s Value for the southern edge
       e Value for the eastern edge
       w Value for the western edge
The script is attached to this e-mail.
What do you think: Is it worth to put in trunk/grass/display/ ? should
the name be d.region or d.region.box or different ?
Jachym
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
(attachments)
d.region (5.06 KB)
On 16/05/08 12:05, Jachym Cepicky wrote:
hi,
more options.
+1
As it is a script, it should go into grass/scripts
> should
d.region sounds good to me in the sense that d.="display a...".
Moritz
