[GRASS-dev] d.rgb and d.zoom
would it be possible to change something so that
d.zoom also understands if only d.rgb was used
in the monitor?
in the monitor?
d.zoom/redraw.c should have an option to use d.redraw to redraw the
display. It's arguable that should be the *only* option (i.e. no rast=
or vector= options).
