[GRASS-dev] d.text vs d.text.freetype vs d.text.new
while starting to write up the changes in GRASS 6.3 for
an upcoming 6.3.0 release, I found that we have
d.text
d.text.freetype
d.text.new
What is the state of d.text.new?
d.text
d.text.freetype
d.text.new
AFAICT, it's essentially a superset of the other two.
Although it lacks the charset=, path= and -c switches from
d.text.freetype, that functionality is available through other means
(-c is implied if text= isn't used, the encoding and path can be set
in the freetypecap file or via d.font[.freetype]).
> d.text
> d.text.freetype
> d.text.new
WRT publishing the name, note that d.text.new must be a temporary name,
and it only exists in the development version (the name will become an
anachronism at some point in the future).
We need to figure out what to do with it, currently IIUC it is mainly
there to help with changing fonts in the GUI-- My guess is that the new
WxPython GUI will place text directly on the canvas and not rely on a
d.* module at all.
So the question is, what is the future of the d.text.* modules as they
will exist to support the command line xmon version of GRASS? And in the
short term, what to rename d.text.new, or will it replace d.text?
Hamish
> > d.text
> > d.text.freetype
> > d.text.new
d.* module at all.
It should replace d.text.
Also, d.text.freetype and d.font.freetype are now essentially
redundant, as d.text.new and d.font can use FreeType fonts.
They may as well be retained in the short term; the existing d.text
should probably be kept as e.g. d.text.old for a transitional period.
