On Jul 24, 2008, at 12:25 PM, <grass-dev-request@lists.osgeo.org> wrote:
Date: Thu, 24 Jul 2008 18:46:31 +0200
From: Moritz Lennert <mlennert@club.worldonline.be>
Subject: [GRASS-dev] d.thematic.area: need for a bit of help in
C-programming/debugging
To: grass-dev <grass-dev@lists.osgeo.org>
Message-ID: <4888B1E7.30208@club.worldonline.be>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Hello,
I'm having a problem with the d.thematic.area module I just committed in
a modified version.
When I use the discontinuities algorithm for calculating the class
breaks, I get segmentation faults, depending on the number of classes I
ask for and on the variable I try to class.
Moritz,
Because I've been trying to help work out how to compile GRASS in aqua TclTk, I don't have a version that can run this for testing at the moment. Is this in 6.4 as well as trunk? I have an x11 version there. If not, I'll try to do an x11 version of trunk to test this when you get this new issue fixed. Thanks again.
Michael
Hello,
a modified version.
Moritz,
I've only committed to trunk. I feel this code is still too fresh to enter 6.4.
Moritz
