Hello Michael,
On line 1081 d.vect.thematic creates a file outtxt.txt in the current directory which then remains there. This file just contains the path to the gismlegend.txt file containing the legend drawing instructions. Can't this information be passed in another way, or at the outtxt.txt file erased at one point ?
Moritz
I can't see any reason for this line. So I commented it out and committed
the change to the cvs. Let me know if it messes up anything I didn't see.
Michael
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
From: Moritz Lennert <mlennert@club.worldonline.be>
Date: Mon, 31 Jul 2006 12:09:00 +0200
To: Michael Barton <michael.barton@asu.edu>, Grass Developers List
<grass-dev@grass.itc.it>
Subject: d.vect.thematic creates outtxt.txt file which is not erased
Hello Michael,
Moritz
I now get the following error, but only in a new location, not in already existing ones. Strange...
couldn't open "/home/mlennert/GRASS/DATA/BE/mlennert/.tmp/geog-pc40/gismlegend.txt": no such file or directory
while executing
"open $legfile r"
(procedure "GmThematic::tleg_item" line 12)
invoked from within
"GmThematic::tleg_item $mon $id"
(procedure "GmThematic::display" line 78)
invoked from within
"GmThematic::display $node $mod"
("thematic" arm line 2)
invoked from within
"switch $type {
group {
GmGroup::display $node $mod
raster {
GmRaster::display $node $mod
labels {
GmLabels::disp..."
(procedure "GmTree::display_node" line 7)
invoked from within
"GmTree::display_node $n $mod"
(procedure "GmGroup::display" line 25)
invoked from within
"GmGroup::display "root" $mod"
(procedure "MapCanvas::runprograms" line 30)
invoked from within
"MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
(procedure "MapCanvas::drawmap" line 43)
invoked from within
"MapCanvas::drawmap $mon"
(procedure "MapCanvas::display_server" line 9)
invoked from within
("after" script)
Cannot reproduce this, so must have been some other problem. Now it seems to work fine.
Moritz
I just love the problems that solve themselves
Michael
phone: 480-965-6213
fax: 480-965-7671
Date: Tue, 01 Aug 2006 14:03:49 +0200
To: Moritz Lennert <mlennert@club.worldonline.be>
Cc: Michael Barton <michael.barton@asu.edu>, Grass Developers List
Subject: Re: [GRASS-dev] Re: d.vect.thematic creates outtxt.txt file which is
not erased
seems to work fine.
Moritz
