Hi devs,
I just committed last changes from Adam, so the d.vect.thematic legend
is now integrated with vector legend. There is couple of options,
which I am not sure what to do about:
-l Create legend information and send to stdout
-e When printing legend info, include extended statistical info from
classification algorithm
-n Do not draw map, only output the legend
legendfile File in which to save d.graph instructions for legend display
Should the behavior be the same for backwards compatibility? Then the
legend info written by -l looks like:
0.000000|0.873239|26|128:0:128
0.873239|4.000000|45|0:128:0
and -le:
Total number of records: 71
Classification of PUMPERS into 2 classes
Using algorithm: *** std ***
Mean: 0.873239 Standard deviation = 0.854641
Stdev multiplied by 1.0000 to define step
and legendfile saves d.graph instructions:
size 8 8
symbol basic/box 25 5 10 black 128:0:128
move 8 9
text 0.000000 - 0.873239 | 26
symbol basic/box 25 5 16 black 0:128:0
move 8 15
text 0.873239 - 4.000000 | 45
OR should the legend information be in the new format:
|||||firestations
0.00 - 0.87|basic/x|5|0:0:0|128:0:128|1|point|26
0.87 - 4.00|basic/x|5|0:0:0|0:128:0|1|point|45
and legendfile would save the new format and not d.graph instructions?
Anna
On 27/08/16 21:44, Anna Petrášová wrote:
Hi devs,
and -le:
size 8 8
move 8 9
move 8 15
|||||firestations
I think that now that we have d.legend.vect, it would be better to do the latter, i.e. don't have d.vect.thematic worry about the d.graph instructions.
Couldn't we just have d.vect.thematic automatically write to the new format in the legend file, but keep the flags for now for backward compatibility, while possible emitting a 'deprecated' warning when they are used ?
Moritz
