[GRASS-dev] d.vect.thematic: v.univar.sh -> v.univar?
can we safely change v.univar.sh -> v.univar in d.vect.thematic?
This might speed up calculations...
If it does extended stats now and the output is the same, it should be an
easy switch.
Michael
On 5/1/07 8:25 AM, "Markus Neteler" <neteler@itc.it> wrote:
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
It seems to be slightly more complicated (I tried), so I
leave it for now.
easy switch.
Michael
> Hi,
> Markus
phone: 480-965-6213
fax: 480-965-7671
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
FBK-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
Markus, could you try the version attached? I think I got it right but
can't access a CVS build right now, so v.univar -e is unavailable for
me right now.
If ok, I'll commit to HEAD.
Daniel.
leave it for now.
> easy switch.
> Michael
> > Hi,
> > Markus
> phone: 480-965-6213
> fax: 480-965-7671
grass-dev mailing list
grass-dev@grass.itc.it
-- Daniel Calvelo Aros
(attachments)
w (36.8 KB)
Ooops, sorry for the noise. I managed to recompile CVS and of course I
had gotten it all wrong. v.univar and v.univar.sh have different
interfaces.
Good news: the attached d.vect.thematic version works using v.univar
Bad news: as pointed out in v.univar source, extended stats
(nonparametric) are only available for points/centroids
Martin, why is it harder to calculate those for area/boundary/line ?
Aren't we just accessing the db corresponding to the layer?
So currently, we can't fully replace v.univar.sh with v.univar for
d.vect.thematic purposes. The clean course of action is to extend
v.univar to calculate extended stats for the rest of types.
Daniel.
me right now.
Daniel.
> leave it for now.
> Markus
> > easy switch.
> > Michael
> > > Hi,
> > > Markus
> > phone: 480-965-6213
> > fax: 480-965-7671
(attachments)
w (36.8 KB)
Replying to myself twice, sorry.
After reading v.univar/main.c more thoroughly, I think I'm
understanding the issue: v.univar.sh is *not* a shell equivalent of
v.univar. Actually, v.univar.sh should have been called v.db.univar.
In v.univar the statistics collected are those of the vector map, not
only of its database: a type=area in v.univar should mean collect
statistics weighted by area and so on.
For d.vect.thematic as it stands now, no information is used about the
geometry, so it only depends on the currently implemented
type=point,centroid behaviour of v.univar.
I commited to CVS.
Daniel.
interfaces.
Daniel.
> me right now.
> Daniel.
> > leave it for now.
> > Markus
> > > easy switch.
> > > Michael
> > > > Hi,
> > > > Markus
> > > phone: 480-965-6213
> > > fax: 480-965-7671
> > _______________________________________________
me right now.
This version would revert all recent g.message changes.
It looks like that you worked on an older file version?
Daniel.
>leave it for now.
>Markus
>> easy switch.
>> Michael
>> > Hi,
>> > Markus
>> phone: 480-965-6213
>> fax: 480-965-7671
> me right now.
For the record: fixed by Daniel in CVS.
While working on the book, I came across this issue again.
I have added it now as scripts/v.db.univar in CVS.
View this message in context: http://www.nabble.com/d.vect.thematic%3A-v.univar.sh-->-v.univar--tf3675636.html#a11270068
Sent from the Grass - Dev mailing list archive at Nabble.com.
