[GRASS-dev] db commands on vectors stored in another mapset
Using the spearfish dataset:
# start grass
grass63 grass/spearfish60/user1/
# dump the table associated with 'bugsites' in PERMANENT
db.select bugsites@PERMANENT
dbmi: Protocol error
# one more try:
db.select bugsites
DBMI-DBF driver error:
Table 'bugsites' doesn't exist.
Error in db_open_select_cursor()
# now with some debugging:
db.select bugsites
D2/5: opendir /usr/local/grass-6.3.svn/driver/db/
D2/5: DBF: db__driver_open_database() name =
'$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/'
D3/5: tokens[0] = $GISDBASE
D3/5: -> /home/dylan/grass
D3/5: tokens[1] = $LOCATION_NAME
D3/5: -> spearfish60
D3/5: tokens[2] = $MAPSET
D3/5: -> user1
D3/5: tokens[3] = dbf
D2/5: db.name = /home/dylan/grass/spearfish60/user1/dbf/
D3/5: SQL statement parsed successfully: select * from bugsites
D2/5: find_table(): table = bugsites
# one more try with the @mapset notation:
D3/5: -> user1
Is this the normal behavior? i.e. I can "use" raster and vector files
across mapsets, but why not vector attributes?
This is on GRASS SVN (31012) x86 and AMD.
As a work-around, it is possible to first copy the vector from one
mapset to another, and then the regular db.* commands will work.
Dylan
Dylan Beaudette pisze:
Because you are using DBF driver and your database is in:
(check with db.connect -p). This results in a different path from mapset to mapset. I guess this is a feature.
In order to use db.select cross-mapset with DBF driver you need to set database= explicitely.
Maciek
Maciek
Thanks Maciek.
I see that the following works as expected:
# not logged into the 'PERMANENT' mapset
db.select bugsites database=/home/dylan/grass/spearfish60/PERMANENT/dbf/
I suppose that altering the behavior of the db.* commands would be dangerous,
and really should respect the current mapset's database connection.
How hard would it be to parse the @mapset, remove it in the actual SQL, but
pass it into the 'database' selection? Or more importantly, is there any way
to make typing 'database=/home/dylan/grass/spearfish60/PERMANENT/dbf/' any
less painfull?
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
> > files across mapsets, but why not vector attributes?
Maciek:
Dylan:
db.select bugsites
dangerous, and really should respect the current mapset's database
connection.
but pass it into the 'database' selection? Or more importantly, is
there any way to make typing
any less painfull?
you could try to use v.db.connect on the original vector and hard code
the database= there instead of using the variables. That would mean you
couldn't easily move/backup the map then and it would be tied to that
dir. Also I'm not sure it would work, but it might.
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
