[GRASS-dev] db.connect exit codes
currently if no DB/driver is defined (new mapset), "db.connect -p" returns
with an error code of 0.
G61> db.connect -p
driver:(null)
database:(null)
schema:(null)
group:(null)
G61> echo $?
0
This makes it hard to test in a script... (v.db.addtable fails)
I assume the (null) comes from printf("%s",..);
Is there anything wrong with setting it to something >0 and ideas on how
to do that?
Hamish
G61> db.connect -p
driver:(null)
database:(null)
schema:(null)
group:(null)
G61> echo $?
0
to do that?
But return code 0 is correct, it means that module successfully finished
and that is true. Module's return code cannot depend on defined driver.
Radim
Hamish
grass-dev mailing list
grass-dev@grass.itc.it
> returns with an error code of 0.
> G61> db.connect -p
> driver:(null)
> database:(null)
> schema:(null)
> group:(null)
> G61> echo $?
> 0
> how to do that?
finished and that is true. Module's return code cannot depend on
defined driver.
Ok, we asked it a question and it answered us accurately & without
encountering any problems. test for "(null)" added to v.db.addtable.
Hamish
