I have a grassgis database with in the mapset 'Permanent' a table
'vegetation_lookup'. I want top copy this table to the current mapset.
The following used to work I think, but now gives me some errors:
ERROR: Unable to create directory '///sqlite' for sqlite database
dbmi: Protocol error
WARNING: Unable to open database <///sqlite/sqlite.db> by driver <sqlite>
I have a grassgis database with in the mapset ‘Permanent’ a table
‘vegetation_lookup’. I want top copy this table to the current mapset.
Looking at the code of db.copy, it is not possible that this ever worked, you need to replace the variables with their actual values.
Markus M
ERROR: Unable to create directory ‘///sqlite’ for sqlite database
On Sat, Mar 14, 2020 at 11:39 PM Markus Metz
<markus.metz.giswork@gmail.com> wrote:
On Sat, Mar 14, 2020 at 3:27 PM Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
> Dear devs,
> db.copy from_driver=sqlite
> from_database=/media/grassdb/biodiv/PERMANENT/sqlite/sqlite.db
> from_table=vegetation_lookup to_driver=sqlite
> to_database=$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
> to_table=vegetation_lookup
Yes, I did work with the actual values, which gave me the error below.
Then I tried the above, but that as you rightly noted, shouldn't, and
didn't work either. In the meantime I recreated the database and did a
fresh install of grass, and now my script works again. I am not sure
which of the two made it work again (should have done this more
systematically), but in any case, thanks for the feedback Markus.
Markus M
> Any idea what I am doing wrong here?
> With kind regards,
> Paulo
> grass-dev mailing list
> grass-dev@lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
On Sat, 14 Mar 2020 at 15:27, Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
Dear devs,
Dear Paulo,
try to protect the to_database string value like
'$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db' otherwise the
variable are replaced with empty value
> Dear devs,
Dear Paulo,
