[GRASS-dev] db.execute: ".execute" suffix missing in man page
In Firefox and Lynx browsers the ".execute" part of
"db.execute" is missing above the module description. It
also not there in "man db.execute" output.
Applies to current 6.3 CVS and checkouts few weeks old. In
6.2 it's OK though.
See a copy/paste:
NAME
   db - Executes any SQL statement.
KEYWORDS
   database, SQL
SYNOPSIS
   db
   db help
   db [-i] [input=name] [driver=name] [database=name]
[--verbose] [--quiet]
Does anybody confirm?
Maciek
G_basename
Confirm:
  $ db.execute --help
  Usage:
   db [-i] [input=name] [driver=name] [database=name] [--verbose]
     [--quiet]
G_parser() does:
  G_basename(tmp_name, "exe");
G_basename() is described thus:
* \fn char * G_basename (char *filename, const char *desired_ext)
* \brief Truncates filename to the base part (before the last '.')
* if it matches the extension, otherwise leaves it unchanged.
But it actually only checks if the specified extension is a prefix of
the actual extension rather than a complete match.
Suggested fix (untested):
char * G_basename(char *filename, const char *desired_ext)
    /* Find the last . in the filename */
    char *dot = strrchr(filename, '.');
    if (dot && G_strcasecmp(dot + 1, desired_ext) == 0)
       *dot = '\0';
    return filename;
G_parser() does:
Oops - that was an oversight on my part.
The reason for that was so that e.g. "tif" can match .tif and .tiff and other usage cases like that. The original usage for G_basename() was checking the output filename for r.out.tiff so it could decide if it should add an extension or not.
      *dot = '\0';
   return filename;
That would break the way it is used in r.out.tiff in some circumstances. I'm thinking it might be easier to conditionalise its use in G_parser() and G_set_program_name() on __MINGW32__ as its only purpose there is to strip out the .exe executable extension on Windows?
Maybe there should be two functions though. Or maybe stripping out the .exe is quite simple and it doesn't need to use G_basename()?
If noone else has fixed this yet I'll try and get to it fairly soon.
Paul
> G_parser() does:
> *dot = '\0';
> return filename;
I suggest fixing G_basename() as above; the current behaviour is
counter-intuitive and undesirable in most cases.
r.out.tiff should check for .tif and .tiff separately. This isn't just
a matter of being able to use G_basename() for other purposes.
r.out.tiff shouldn't treat anything other than .tif or .tiff (modulo
case) as a TIFF extension; cf. "area.around.Tifton_GA".
      *dot = '\0';
   return filename;
I agree; have committed changes to G_basename() and r.out.tiff accordingly. Hopefully the db.execute problem should be fixed now.
Paul
Paul
db.execute's manual looks OK now. Thanks.
Maciek
