[GRASS-dev] db.execute segfaults on simplest SQL query
This works:
$ v.db.select pts_out col=rast_val
rast_val
108.3656
102.906
41.60993
but, it's SQL counterpart segfaults:
$ echo "SELECT rast_val FROM pts_out" | db.execute
Segmentation fault
dbmi: Protocol error
ERROR: Error while executing: 'SELECT rast_val FROM pts_out
DBF driver. Tested with latest 6.3 CVS. Has been the same in
6.3 CVS of 17.09.2007 at least and 6.2.2 CVS of 13.09.2007.
Shall I open a ticket in the tracker? If more info or test
dataset is needed pls let me know.
Maciek
Remember that v.db.select can follow to tables in
different mapsets while the db.* command cannot.
Can this be the issue?
If not, could you provide some code to repeat in
Spearfish or North Carolina dataset?
On Mon, Oct 08, 2007 at 10:08:59PM +0200, Maciej Sieczka wrote:
This works:
rast_val
108.3656
102.906
41.60993
Segmentation fault
Maciek
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
On Mon, October 8, 2007 22:08, Maciej Sieczka wrote:
This works:
rast_val
108.3656
102.906
41.60993
Segmentation fault
All select queries need to be sent via db.select. All other queries via
db.execute. I.e. try
$ echo "SELECT rast_val FROM pts_out" | db.select
Moritz
This works:
rast_val
108.3656
102.906
41.60993
Segmentation fault
Yes, perfect. Sorry for false alarm.
Anyway, if db.execute could not segfault and say something
instructive it would be great. Eg.:
"db.execute does not support SELECT queries. Use db.select
instead."
Maciek
>> This works:
>> rast_val
>> 108.3656
>> 102.906
>> 41.60993
>> Segmentation fault
instead."
Committed to CVS.
73, de Brad KB8UYR/6 <rez touchofmadness com>
