[GRASS-dev] db.join script wanted
anyone willing to write a db.join addon? Of course table joining is
not a complex task but an addon offers the advantage to also perform
as desired when the user is tired :slight_smile: - less error prone.
Perhaps just derive from
https://trac.osgeo.org/grass/browser/grass/trunk/scripts/v.db.join/v.db.join.py
thanks
2016-03-08 1:06 GMT+01:00 Markus Neteler <neteler@osgeo.org>:
or v.db.join could call new db.join (?) Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Yes, this might be the best to avoid redundancy.
thanks
Hi
I uploaded a first db. join script to addons. r68028.
Something is missing, can anyone please revise it?
Thanks
Thanks Markus, this looks useful. I’ll give it a try when appearing in g.extension. In the meantime, a quick questions: how does this extension differ from v.db.join? With db.join, is it possible to join two tables, including tables that are not attribute tables of a vector layer?
Paulo
On Wed, Mar 9, 2016 at 11:13 AM, Markus Neteler <neteler@osgeo.org> wrote:
Hi
Thanks
grass-dev mailing list
grass-dev@lists.osgeo.org
It should be there…
Once db.join works, v.db.join should call it, and the respective part be removed from v.db.join.
Yes, exactly. It is not related to maps at all. It fills the gap of handling table joins.
Just it needs to be reviewed…
Best
On Wed, Mar 9, 2016 at 1:09 PM, Markus Neteler <neteler@osgeo.org> wrote:
On Mar 9, 2016 12:12 PM, "Paulo van Breugel" <p.vanbreugel@gmail.com>
wrote:
> Thanks Markus, this looks useful. I'll give it a try when appearing in
g.extension.
It should be there...
It is in svn I saw, but it doesn't show up in g.extension.. perhaps because
I am on 7.1?
v.db.join?
Cool, very welcome function
Just it needs to be reviewed...
Will try later today or tomorrow
Best
On Mar 9, 2016 1:36 PM, “Paulo van Breugel” <p.vanbreugel@gmail.com> wrote:
It is in svn I saw, but it doesn’t show up in g.extension… perhaps because I am on 7.1?
This does not matter. I didn’t yet add it to the parent Make file because it is not ready.
Just take it from trac/svn from now…
Hoi Markus
Still not there via g.extension, but I copied the script to the script folder.
I tried with two tables (both created in an external sqlite editor),
Table 1: columns A (integer, key) and B (float)
Table 2: columns A (integer, key) and C (float)
First observation: using the GUI, the drop down menu for the identifier column shows the column names of Table 1 instead of Table 2.
I tried to link the two on the first columns and on the second columns. In both cases I got an error message, copied below:
db.join table=test1 column=A other_table=test2 other_column=A
  File "/home/paulo/.grass7/addons/scripts/db.join", line 170, in <module>    sys.exit(main())
  File "/home/paulo/.grass7/addons/scripts/db.join", line 152, in main columns=colspec)
  File "/usr/local/grass7/grass-7.1.svn/etc/python/grass/script/core.py", line 408, in run_command ps = start_command(*args, **kwargs)
  File "/usr/local/grass7/grass-7.1.svn/etc/python/grass/script/core.py", line 377, in start_command return Popen(args, **popts)
  File "/usr/local/grass7/grass-7.1.svn/etc/python/grass/script/core.py", line 74, in __init__ subprocess.Popen.__init__(self, args, **kwargs)
  File "/usr/lib/python2.7/subprocess.py", line 710, in __init__  errread, errwrite)
  File "/usr/lib/python2.7/subprocess.py", line 1327, in _execute_child raise child_exception
OSError: [Errno 2] No such file or directory
Paulo
On Mar 9, 2016 5:25 PM, “Paulo van Breugel” <p.vanbreugel@gmail.com> wrote:
Hoi Markus
Mhh, perhaps I mixed something up there.
File “/home/paulo/.grass7/addons/scripts/db.join”, line 170, in sys.exit(main())
File “/home/paulo/.grass7/addons/scripts/db.join”, line 152, in main columns=colspec)
File “/usr/local/grass7/grass-7.1.svn/etc/python/grass/script/core.py”, line 408, in run_command ps = start_command(*args, **kwargs)
File “/usr/local/grass7/grass-7.1.svn/etc/python/grass/script/core.py”, line 377, in start_command return Popen(args, **popts)
File “/usr/local/grass7/grass-7.1.svn/etc/python/grass/script/core.py”, line 74, in init subprocess.Popen.init(self, args, **kwargs)
File “/usr/lib/python2.7/subprocess.py”, line 710, in init errread, errwrite)
File “/usr/lib/python2.7/subprocess.py”, line 1327, in _execute_child raise child_exception
That one I fixed 30min ago or so in Svn.
Please check again.
Paulo
Thanks, db.join table=test1 column=A other_table=test2 other_column=A now works. When trying to link the two tables on column B and C, it doesn’t, which is because both tables have a column A.
GRASS 7.1.svn (AEA):~ > db.join table=test1 column=B other_table=test2 other_column=C
WARNING: SQLite driver: unable to parse decltype: REAL(20)
WARNING: SQLite driver: column 'C', SQLite type 2 is not supported
DBMI-SQLite driver error:
Error in sqlite3_prepare():
duplicate column name: A
ERROR: Error while executing: 'ALTER TABLE test1 ADD COLUMN A INTEGER(20)'
ERROR: Unable to add column <A>.
The warnings were not shown when linking via columns A, so I assume they are not a problem? As for the problem with the duplicate column name, would it be possible to add the option to define a prefix which is added to the column of the second table if a column with the same name exists in the first table (with a default prefix if none is given by the user)?
Works now
Hoi Markus
Please check again.
Paulo
Hi
I hope that another developer picks it up add I am traveling…
Thanks
Hoi Markus
Works now
Please check again.
Paulo
On 9 March 2016 at 18:01, Markus Neteler <neteler@osgeo.org> wrote:
Hi
I hope that another developer picks it up add I am traveling...
I'm working on it, but for me it doesn't work
I'll update you
Thanks
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
Hi
I’m working on it, but for me it doesn’t work
Yeah… I think
LEFT OUTER JOIN
must be used, at least with sqlite backend.
I’ll update you
Thanks
Thanks
ciao
Luca
www.lucadelu.org
Hi
I'll update you
Ok, I was wrong it works, but there is a problem.
I'm not able to read the new columns. I try to explain you
I imported the two attached csv files (table1 without header and
table2 with header)
db.in.ogr input=/tmp/table1.csv output=table1
db.in.ogr input=/tmp/table2.csv output=table2
db.join table=table1 column=field_1 other_table=table2 other_column=id
db.select table=table1
WARNING: SQLite driver: unable to parse decltype: TEXT(1000)
WARNING: SQLite driver: column 'id', SQLite type 3 is not supported
WARNING: SQLite driver: column 'label', SQLite type 3 is not supported
field_1|field_2
1|100
2|100
3|200
4|100
5|200
6|100
7|200
8|200
9|100
10|100
but the table is correct in sqlite3
sqlite3 grassdata/gauss_boaga/lucadelu/sqlite/sqlite.db
SQLite version 3.10.2 2016-01-20 15:27:19
Enter ".help" for usage hints.
sqlite> select * from table1;
1|100|1|terra
2|100|2|mare
3|200|3|mare
4|100|4|terra
5|200|5|terra
6|100|6|mare
7|200|7|mare
8|200|8|terra
9|100|9|mare
10|100|10|terra
sqlite> .schema table1
CREATE TABLE table1(field_1 CHARACTER, field_2 CHARACTER, id
TEXT(1000), label TEXT(1000));
The problem is the different type of columns, I'll look on the code later
ciao
Luca
www.lucadelu.org
(attachments)
table1.csv (61 Bytes)
table2.csv (85 Bytes)
On 9 March 2016 at 19:11, Markus Neteler <neteler@osgeo.org> wrote:
Yeah.. I think
LEFT OUTER JOIN
no, the code is working quiet well, look to m other mail. it seems a
column type problem
ciao
Luca
www.lucadelu.org
> Yeah.. I think
> LEFT OUTER JOIN
The code now assumes a 1:1 relationship, is that right?
so if Table 1
A|B
1|2
2|2
and Table 2
A|C
1|3
1|4
2|6
After joining Table 1 looks like
A|B|C
1|2|3
2|2|6
If correct, it might be good to clearly explain this in the documentation?
I wouldn't mind doing that if a final version is ready. At some point it
might be a nice feature to have the option to select the kind of
relationship. On the other hand, that may complicate things to the point
that one may as well use db.execute.
column type problem
ciao
Luca
www.lucadelu.org
On Wed, Mar 9, 2016 at 8:11 PM, Paulo van Breugel
> Yeah.. I think
> LEFT OUTER JOIN
so if Table 1
A|B
1|2
2|2
and Table 2
A|C
1|3
1|4
2|6
A|B|C
1|2|3
2|2|6
If correct, it might be good to clearly explain this in the documentation? I
wouldn't mind doing that if a final version is ready. At some point it might
be a nice feature to have the option to select the kind of relationship.
Yes - with a flag that could be solved or better a "method" parameter.
Consider this SQLite example: JOIN versus LEFT OUTER JOIN:
# Preparation
sqlite3 joinexample.db
# create first table holding data:
CREATE TABLE data (year, month, day, value);
INSERT INTO data VALUES(2003,10,12,12);
INSERT INTO data VALUES(2003,11,24,10);
INSERT INTO data VALUES(2003,11,25,10);
INSERT INTO data VALUES(2003,11,26,10.9);
INSERT INTO data VALUES(2003,11,27,11);
INSERT INTO data VALUES(2003,11,28,11.6);
INSERT INTO data VALUES(2003,12,2,8);
#create second table holding names
CREATE TABLE monthnames (number, month);
INSERT INTO monthnames VALUES(11,'November');
INSERT INTO monthnames VALUES(12,'December');
# check
sqlite> .schema
sqlite> SELECT * FROM data;
2003|10|12|12
2003|11|24|10
2003|11|25|10
2003|11|26|10.9
2003|11|27|11
2003|11|28|11.6
2003|12|2|8
sqlite> SELECT * FROM monthnames;
11|November
12|December
# JOIN: (--> this will omit all non-matching lines!)
sqlite> SELECT data.year, data.month, monthnames.month, data.day, data.value
        FROM data,monthnames
        WHERE monthnames.number=data.month;
2003|11|November|24|10
2003|11|November|25|10
2003|11|November|26|10.9
2003|11|November|27|11
2003|11|November|28|11.6
2003|12|December|2|8
# LEFT JOIN (sort of): (--> this will keep also non-matching lines)
        FROM data LEFT OUTER JOIN monthnames
        ON monthnames.number=data.month;
2003|10||12|12
# save result to table:
sqlite> CREATE TABLE datajoin AS
sqlite> SELECT * FROM datajoin;
2003|10||12|12
# Done.
So, I would like to see both methods supported one day :slight_smile:
&lt;
p.vanbreugel@
&gt; wrote:
On Wed, Mar 9, 2016 at 7:14 PM, Luca Delucchi &lt;
lucadeluge@
&gt; wrote:
On 9 March 2016 at 19:11, Markus Neteler &lt;
neteler@
&gt; wrote:
> Yeah.. I think
> LEFT OUTER JOIN
so if Table 1
A|B
1|2
2|2
and Table 2
A|C
1|3
1|4
2|6
A|B|C
1|2|3
2|2|6
documentation? I
might
# Preparation
# check
sqlite> .schema
2003|10|12|12
2003|11|24|10
2003|11|25|10
2003|11|26|10.9
2003|11|27|11
2003|11|28|11.6
2003|12|2|8
11|November
12|December
data.value
data.value
2003|10||12|12
data.value
2003|10||12|12
# Done.
grass-dev@.osgeo
+1
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/db-join-script-wanted-tp5254985p5255479.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
