do you consider a db.join script to be useful?
db.join --help
Description:
Allows to join a table into another table.
Keywords:
database, attribute table
Usage:
db.join table=name column=string otable=name ocolumn=string
[--verbose] [--quiet]
Flags:
--v Verbose module output
--q Quiet module output
Parameters:
table Table to join into
column Join column in first table
otable Other table name
ocolumn Join column in other table
what it does:
- check for duplicate column names, adds a "b" if found
- adds new column(s) to be joined
- joins (all expect DBF is supported)
On Fri, Aug 21, 2009 at 1:07 AM, Markus Neteler<neteler@osgeo.org> wrote:
db.join --help
Description:
Keywords:
Usage:
For now in Addons. Install with:
g.extension db.join
Hi Markus,
Does your message say that all but DBF back-ends are supported?
Dylan
On Thu, Aug 20, 2009 at 4:07 PM, Markus Neteler<neteler@osgeo.org> wrote:
db.join --help
Description:
Keywords:
Usage:
Flags:
Parameters:
what it does:
grass-dev mailing list
grass-dev@lists.osgeo.org
On Fri, Aug 21, 2009 at 5:42 PM, Dylan
Beaudette<dylan.beaudette@gmail.com> wrote:
Hi Markus,
Yes - DBF isn't quite SQL capable... same thing as for v.db.join and
other more interesting SQL features.
I usually use SQLite as backend.
