[GRASS-dev] db.login: interactive PW implemented
when using db.login, I disliked to enter the password
in cleartext on command line. I have implemented an interactive
password query. The behaviour is now like this:
Example 1: Username and password specified:
  db.login user=bacava pass=secret
Example 2: Username and empty password specified:
  db.login user=bacava pass=""
Example 3: Username specified, password will be queried interactively:
The only thing which I don't know how to fix is that
G_gets() echoes the password. I wonder if we could have
a G_gets_silent() or something (lib/gis/gets.c).
(attachments)
db_login.diff (775 Bytes)
struct termios tios, tios2;
tcgetattr(STDIN_FILENO, &tios);
tios2 = tios;
tios2.c_lflag &= ~ECHO;
tcsetattr(STDIN_FILENO, TCSAFLUSH, &tios2);
read password
tcsetattr(STDIN_FILENO, TCSANOW, &tios);
? OBJ.x86_64-unknown-linux-gnu
Index: main.c
RCS file: /grassrepository/grass6/db/db.login/main.c,v
retrieving revision 1.5
diff -u -r1.5 main.c
--- main.c 15 Nov 2006 13:36:28 -0000 1.5
+++ main.c 15 Nov 2006 13:56:06 -0000
@@ -1,5 +1,6 @@
#include <stdio.h>
#include <stdlib.h>
+#include <unistd.h>
#include <string.h>
#include <grass/gis.h>
#include <grass/dbmi.h>
@@ -53,6 +54,8 @@
   exit(EXIT_FAILURE);
     /* set connection */
+ if (!password->answer && isatty(fileno(stdin)) )
+ G_message("Enter your password:");
     if ( db_set_login ( driver->answer, database->answer, user->answer, password->answer ) == DB_FAILED ) {
   G_fatal_error ( _("Cannot set user/password") );
grass-dev mailing list
grass-dev@grass.itc.it
[I hit "send" too soon on the previous attempt.]
Roughly:
  #include <termios.h>
  #include <unistd.h>
  tios2 = tios;
  /* read password */
However, BSD historically used gtty/stty instead of tc{get,set}attr,
and some older systems used ioctl(TCGETS)/ioctl(TCSETS) (IIRC, Linux'
tc{get,set}attr are implemented on top of the ioctl()s).
And Windows uses something completely different (conio.h, maybe?).
Thanks, Glynn!
Implemented and working on Linux. The interactive password query is
now no longer echoeing the PW.
Paul: could you please make a test on Windows?
Any BSD tester around?
Roughly:
  #include <unistd.h>
  tios2 = tios;
  /* read password */
Roughly:
  #include <unistd.h>
  tios2 = tios;
  /* read password */
BTW, there is some code in 5.3 to do this (when I wrote my previous
message, I could have sworn that something in GRASS did this, but I
couldn't find it at that time), in:
  src/libes/unused/unsupported/dig_to_dlg/tty.c
  src/libes/unused/unsupported/dlglabel/tty.c
  src/paint/Interface/driverlib/io.c
  src/paint/drivers.junk/anadex/open.c
  src/paint/drivers.junk/epson.24.180/open.c
  src/paint/drivers.junk/epson.24.90/open.c
  src/paint/drivers.junk/epson.8.90/open.c
  src.contrib/SCS/paint/Drivers/driverlib/io.c
  src.contrib/SCS/paint/Interface/driverlib/io.c
[Note that most of the above are essentially clones of each other.]
Of the above, src/paint/Interface/driverlib/io.c includes code for all
three interfaces, decided by header checks.
tcsetattr() uses "struct termios" from <termios.h>, ioctl(TCSETA) uses
"struct termio" from <termio.h>, while stty() uses "struct sgttyb"
from <sgtty.h>.
Also, note that using stty() requires $(COMPATLIB) to be added to the
link flags.
Windows has separate getch() and getche() functions; the latter echoes
characters as they are typed, the former doesn't. You can't disable
echoing for stdio.
BTW, some Unices (including Linux) have a getpass() function (not
defined by any standard, AFAICT). This specifically opens /dev/tty
rather than using stdin, so it works even if stdin is redirected.
Glynn Clements wrote on 11/16/2006 03:03 PM:
Roughly:
  #include <unistd.h>
  tios2 = tios;
  /* read password */
from <sgtty.h>.
link flags.
echoing for stdio.
Thanks, but I am afraid that I am unable to decide/implement the further
suggestions - too
complicated for me.
suggestions - too
complicated for me.
At a minimum, the new code should be conditional upon HAVE_TERMIOS_H,
otherwise db.login will simply fail to compile on platforms which
don't have it (e.g. Windows).
> suggestions - too
> complicated for me.
OK, I have conditionalized the hidden password upon HAVE_TERMIOS_H.
