[GRASS-dev] db.login with postgresql and non standard port
Hi devs,
I have a problem using db backend different to SQLite.
I have a postgresql server running on port 5433, I set up the
connection like this
db.connect driver=pg database=grassdata
db.login user=lucadelu port=5433 host=localhost
but if I try to create new vector with v.random for example I get this error
v.random -z output=random npoints=50 column=zz
D1/1: G_set_program_name(): v.random
D1/1: Vect_open_new(): is_tmp = 0
D1/1: Vect_open_new(): name = random with_z = 1 is_tmp = 0
D1/1: Vect_set_thresh(): thresh = 0.000000
D1/1: G_find_vector2(): name=random mapset=osm_compare
D1/1: V1_open_new_nat(): name = random with_z = 1 is_tmp = 0
D1/1: dig__write_head()
D1/1: write coor size (0) to head
D1/1: dig_spidx_init(), 2 dims
D1/1: Vect_open_sidx(): name = random mapset= osm_compare mode = new
D1/1: Memory based spatial index
D1/1: Vect_default_field_info(): map = random field = 1
D1/1: db_d_init_error(): PostgreSQL
DBMI-PostgreSQL errore del driver:
Connection failed.
connessione al server fallita: File o directory non esistente
        Verifica che il server locale sia in funzione e che
        accetti connessioni sul socket di dominio Unix
"/var/run/postgresql/.s.PGSQL.5432"
Connection failed.
ATTENZIONE: Impossibile aprire il database <grassdata> dal driver <pg>
ERRORE: Impossibile aprire il database <grassdata> col driver <pg>
D1/1: Vect_close(): name = random, mapset = osm_compare, format = 0,
level = 1, is_tmp = 0
D1/1: close history file
D1/1: V1_close_nat(): name = random mapset= osm_compare
D1/1: get coor info:
/home/lucadelu/grassdata/utm32N/osm_compare/vector/random/coor
D1/1: Vect_coor_info(): Info->size = 0, Info->mtime = 1457452927
D1/1: Vect_write_dblinks(): map = random, mapset = osm_compare
D1/1: Dblinks written
D1/1: Vect__open_old(): name = random, mapset = osm_compare, layer =
NULL, update = 0, head_only = 1, is_tmp = 0
D1/1: Map: name = random, mapset = osm_compare, temporary = 0
D1/1: Vector format: 0 (native)
D1/1: Vect__read_head(): vector = random@osm_compare
D1/1: Level request = 1
D1/1: Vect__open_old(): vector opened on level 1
D1/1: Vect_read_dblinks(): map = random, mapset = osm_compare
D1/1: Dblinks read
D1/1: dbln file: /home/lucadelu/grassdata/utm32N/osm_compare/vector/random/dbln
D1/1: G_set_program_name(): g.gisenv
Is this a bug or I'm doing something wrong?
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
2016-03-08 17:08 GMT+01:00 Luca Delucchi <lucadeluge@gmail.com>:
what says
db.login -p
? Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On 08/03/16 17:08, Luca Delucchi wrote:
Hi devs,
I would expect the port parameter to be set in db.connect, not in db.login. Have you tried that ? See "PostgreSQL with different port" in the db.connect manual.
Moritz
2016-03-09 17:14 GMT+01:00 Moritz Lennert <mlennert@club.worldonline.be>:
connection details (user/password/port/hostname) are part of db.login,
not db.connect (>= 7.1.)
manual.
Not valid for 7.1. Martin
Martin Landa
On 09/03/16 19:54, Martin Landa wrote:
manual.
Oh, yes, I see. Thanks for the clarification. I must have missed that change. What was the reasoning behind this change ? Is this in the idea that one might want to move a database to another host and/or port, but not change the mapset and vector map connection settings ? Or something else ?
Moritz
On 8 March 2016 at 17:13, Martin Landa <landa.martin@gmail.com> wrote:
what says
db.login -p
db.login -p
sqlite|$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db|lucadelu|||
sqlite|/grassdata,nc_spm_08,lucadelu,sqlite.db|lucadelu|||
pg|host=localhost,dbname=pygrassdb_doctest|lucadelu|||
pg|grassdata|lucadelu|||
why duplicate rows?
? Ma
ciao
Luca
www.lucadelu.org
2016-03-10 9:01 GMT+01:00 Luca Delucchi <lucadeluge@gmail.com>:
db.login -p
well, the lines are duplicated after substitution. I don't know, your
run command which defined db connection ones without and ones with
substitution. Ma
Martin Landa
2016-03-10 9:01 GMT+01:00 Moritz Lennert <mlennert@club.worldonline.be>:
I would say, you are right. db.login was prepared, the code was just
commented out and dbmi library needed to implement this functionality.
Ma
Martin Landa
On 10 March 2016 at 09:10, Martin Landa <landa.martin@gmail.com> wrote:
db.login -p
substitution. Ma
No, I donit think so. I just run
db.connect driver=pg schema=public database=grassdata
db.connect -p
driver: pg
database: grassdata
schema: public
group:
db.login driver=pg database=grassdata user=lucadelu port=5433 host=localhost --o
db.login -p
db.tables
DBMI-PostgreSQL driver error:
Connection failed.
could not connect to server: No such file or directory
        Is the server running locally and accepting
        connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
Connection failed.
ERROR: Unable to open database <grassdata>
So the port it is not stored, and also in db.login -p there is
something strange with
where dbname=pygrassdb_doctest should be dbname=grassdata
ciao
Luca
www.lucadelu.org
db.login -p
substitution. Ma
db.connect -p
driver: pg
database: grassdata
schema: public
group:
db.login -p
db.tables
Connection failed.
Connection failed.
Could this be "left-overs" from pre-grass71 ? How about erasing (or renaming $HOME/.grass7/dblogin) and trying again ?
Moritz
2016-03-10 9:42 GMT+01:00 Luca Delucchi <lucadeluge@gmail.com>:
db.login -p
these two lines are apparently some leftover from other commands you
entered in the past. There is no relation to PG. Ma
Martin Landa
On 10 March 2016 at 09:59, Martin Landa <landa.martin@gmail.com> wrote:
db.login -p
ok, removed the file as proposed by Moritz, set again the login
db.login -p
but the file is correct
cat /home/lucadelu/.grass7/dblogin
pg|grassdata|lucadelu||localhost|5433
Probably something is wrong in the db library because it seems to not
consider the port (and probably also the host)
ciao
Luca
www.lucadelu.org
2016-03-10 10:15 GMT+01:00 Luca Delucchi <lucadeluge@gmail.com>:
right, please fill a ticket, Martin
Martin Landa
