6.3cvs (1-2 days old), OGR linked shapefile (v.external),
G63> v.extract in=admin98 out=antarctica98 \
where="ADMIN_NAME = 'Antarctica'"
Load cats from the database (table = admin98, db =
/home/hamish/grassdata/world_ll/PERMANENT/external).
1 cats loaded from the database
Building topology ...
276 primitives registered
Building areas: 100%
138 areas built
138 isles built
Attaching islands: 100%
Attaching centroids: 100%
Topology was built.
Number of nodes : 276
Number of primitives: 276
Number of points : 0
Number of lines : 0
Number of boundaries: 138
Number of centroids : 138
Number of areas : 138
Number of isles : 138
Writing attributes ...
Layer 1
ERROR 1: SQL: Failed to identify field:0
DBMI-OGR driver error:
Cannot select:
select * from admin98 where 0 = 1
WARNING: Cannot open select cursor: 'select * from admin98 where 0 = 1'
WARNING: Cannot copy table
Done.
The vector map is extracted ok, but the attr table isn't copied.
| Number of dblinks: 0
Hamish
ps - general IPY interest of what happens in a "corner" case:
pic of output v.proj'd into EPSG#3033 attached (LCC). blue crosses
indicate +lat_1 and +lat_2 for the projection, centered on the Lambert
Glacier (no relation) and Amery Ice Shelf. d.grid -g goes a bit nuts
once you zoom out so far from the projection's region of purpose; v.proj
held up pretty well except for directly across from +lon_0=70 (middle
bottom). 180 lon break is there but easily cleaned with v.clean tool=rmsa
PROJ4 values for EPSG Polar Stereographic epsg codes don't exist.
