[GRASS-dev] DBMI troubles on Win32
I have tried a GRASS vector map linked to a DFB table.
My test data set also is very small and simple.
I keep running v.info -c on it and after about 10-15 runs it
usually freezes and I have to CTRL+C it.
I will do some more testing using breakpoints to see which
one of the dbmilib functions is causing this.
Strange ...
On Fri, March 9, 2007 09:18, Benjamin Ducke wrote:
I am currently doing a lot of testing for GRASS 6.3. on the mingw/msys
platform (the same that comes with QGIS).
There seems to be a problem related to the DBMI protocol. Modules that
access attribute data via the GRASS DBMI lib have a habit of hanging
once in a while. I have seen this happen on half a dozen different
machines with Win2000 and XP.
An example is v.info -c. The module simply hangs and has to be killed
and restarted until it does its work.
The strange thing is that I cannot find any pattern here: sometimes
dozens of runs show no problems at all and sometimes I have to restart
a module several times until it starts running.
Also, this seems to concern only the first DB access. I have a module
here that does hundreds of DB accesses during each run. If the first
one goes OK, all the others will be fine too ...
I am using the latest 6.3 CVS sources for my tests.
I am at a loss here. Can anyone confirm this problem?
I can't with the native winGRASS (not QGIS), at least not using v.info
-c as a test case within spearfish. But there tables are very small.
Which type of files did you try this on ?
Moritz
