[GRASS-dev] Dead code
The following directories contain code but aren't built:
  display/d.colors
  display/d.extract
  display/d.measure
  display/d.what.rast
  display/d.what.vect
  display/d.zoom
  general/g.pnmcat
  general/g.setproj
  imagery/i.class
  imagery/i.ortho.photo/i.ortho.init
  imagery/i.ortho.photo/i.ortho.transform
  imagery/i.points
  imagery/i.vpoints
  raster/r.digit
  raster/r.grow
  raster/r.le
  raster/r.li/r.li.setup
  raster/r.watershed/shed
  vector/v.label.sa
  vector/v.mapcalc
Are there plans to "resurrect" any of these within the foreseeable
future? If not, they should be removed.
Also, raster/wildfire contains just a README and a Makefile, the
actual modules (r.ros, r.spread, r.spreadpath) having been moved up
into the parent raster directory.
The Makefile serves no purpose, and the README (which contains a link
to sample data) won't be seen by end users; its content should
probably be added to the manual pages for the relevant modules.
Finally, I feel that v.in.dwg should be moved to addons.
On Fri, May 30, 2014 at 1:57 AM, Glynn Clements
[no idea]
i.ortho.photo should remain, I hope to get this updated to G7 at some point.
        imagery/i.points
        imagery/i.vpoints
... maybe no longer needed?
        raster/r.digit
.. a r.digit tool would be nice to have.
        raster/r.grow
        raster/r.le
... all delete candidates.
... dunno.
        vector/v.label.sa
... merge with v.label?
        vector/v.mapcalc
... dunno.
Some yes, some no, see above.
.. sounds like leftover?
yes.
yes.
my 0.02 cents
        display/d.colors
--> some updates in r62458 but AFAIR the curses support got dropped,
so trash d.colors? Or move to addons?
        display/d.extract
--> likely obsolete. Trash it or move to Addons?
        display/d.measure
        display/d.what.rast
        display/d.what.vect
--> likely obsolete. Replaced with Python scripts in scripts/. Trash
both or move to Addons?
        display/d.zoom
        general/g.pnmcat
--> "Concatenate PNM tiles into a single image, was used by NVIZ". No idea.
        general/g.setproj
--> lacking G_ask_datum_name(). Trash it or move to Addons?
        imagery/i.class
--> likely obsolete. Replaced with g.gui.iclass. Trash it or move to Addons?
--> likely needed. See http://trac.osgeo.org/grass/ticket/2461
        imagery/i.points
        imagery/i.vpoints
--> uses unsupported curses, so trash or move to Addons? ( I think trash)
        raster/r.digit
--> no idea
        raster/r.grow
--> trash
        raster/r.le
--> since it is unmaintained, move to Addons
--> Luca? Can we remove it? Replaced with g.gui.rlisetup
--> no idea
        vector/v.label.sa
--> lacks find_font_from_freetypecap(). See
http://trac.osgeo.org/grass/ticket/1942 and r34923
        vector/v.mapcalc
--> move to Addons
--> cleaned up now.
--> yes, move to Addons
More opinions?
On 29 October 2014 00:18, Markus Neteler <neteler@osgeo.org> wrote:
        imagery/i.class
trash
+1000
        raster/r.le
is it different from r.li?
I'm going to remove it
More opinions?
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
2014-10-29 0:18 GMT+01:00 Markus Neteler <neteler@osgeo.org>:
        general/g.setproj
isn't it replaced by `g.proj -c` ?
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://www.gismentors.eu/mentors/landa
        imagery/i.class
it's same code as in G6, so removed in r62464-5.
Martin
Martin Landa
> display/d.colors
> display/d.extract
> display/d.measure
> display/d.what.rast
> display/d.what.vect
> display/d.zoom
Trash. I can't see these being resurrected in anything like their
existing form. Any replacements would presumably be in Python/wx.
> general/g.pnmcat
Presumably the wxPython replacement doesn't need it, so remove.
> general/g.setproj
Are the replacements sufficient? g.setproj had a lot of logic for
dealing with the relationships between various parameters. Has that
been incorporated into the GUI? Is it unnecessary? Or does everyone
just use EPSG codes now?
> imagery/i.class
It looks like Martin has already answered that one.
> imagery/i.points
> imagery/i.vpoints
Trash. Anything that uses curses and R_get_location_with_* as a GUI is
never going to work with 7.x, and any replacement will likely be
written in Python.
> raster/r.digit
--> no idea
Same issue as d.* and i.* modules above. Trash.
> vector/v.label.sa
That could probably be fixed easily enough. But it probably shouldn't
be dealing with FreeType directly. I'd suggest using the display API,
specifically D_get_text_box() rather than trying to calculate a
skyline.
On Thu, Oct 30, 2014 at 8:40 AM, Glynn Clements
I have collected the comments here:
http://grasswiki.osgeo.org/wiki/GRASS_7_ideas_collection#Dead_code_cleanup
> general/g.setproj
No, EPSG codes do not represent all. Especially since we still need to
update the CSV files included in lib/proj/ which are pretty dated now.
See README.txt therein for a better approach.
> imagery/i.class
It is yet lacking the cleanup of documentation references:
find . -type f | grep -v 'svn/pristine' | grep -v 'locale' | xargs
grep "i\.class"
To add to the discussion of removing potentially obsolete code:
Additionally I have added to the Wiki page:
* r.bitpattern: Remove r.bitpattern since r.mapcalc does it more nicely now - ?
* raster/r.in.arc and raster/r.out.arc (use r.in.gdal/r.out.gdal) - ?
* raster/r.in.tiff and raster/r.out.tiff (use r.in.gdal/r.out.gdal) - ?
IMPORTANT: we need to update accordingly
http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures#Removedmodules
2014-10-30 10:49 GMT+01:00 Markus Neteler <neteler@osgeo.org>:
grep "i\.class"
done in 62487.
done [1].
Martin
[1] http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures?action=diff&version=254&old_version=253
Martin Landa
http://gismentors.eu/mentors/landa
If the connection is available why not retrieve these information
directly from the web?
something like:
In [1]: import urllib2
In [2]: def get_epsg_wkt(epsg):
   ...: response =
urllib2.urlopen('http://epsg.io/\{epsg\}\.wkt&#39;\.format\(epsg=epsg\)\)
   ...: return response.read()
In [3]: print(get_epsg_wkt(3003))
PROJCS["Monte Mario / Italy zone 1",GEOGCS["Monte
Mario",DATUM["Monte_Mario",SPHEROID["International
1924",6378388,297,AUTHORITY["EPSG","7022"]],TOWGS84[-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68],AUTHORITY["EPSG","6265"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4265"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",9],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",1500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["X",EAST],AXIS["Y",NORTH],AUTHORITY["EPSG","3003"]]
... internet connection is not necessarily available.
why not retrieve these information directly from the web?
something like:
   ...: response =
This delivers only one of several TOWGS84 parameters.
In the location manager is a selection dialog with respect to the
actual EPSG code and the datums stored in
lib/gis/datum.table
lib/gis/datumtransform.table
And even if it is, not everyone wants to send a log of their actions
to a third party.
please express your opinion on the remaining issues:
? unclear: Trash or move to addons?
* display/d.colors - ?
* display/d.extract - ?
* display/d.measure - ?
* general/g.setproj - partially replaced by `g.proj -c` but contains
still useful logic
* r.bitpattern: Remove r.bitpattern since r.mapcalc+i.modis.qa does it
more nicely now - ?
* raster/r.grow - ?
* raster/r.le - ?
* raster/r.watershed/shed - ?
* vector/v.mapcalc - ?
* selected r.stream modules: r.stream.channel, r.stream.distance,
r.stream.order, r.stream.segment, r.stream.slope, r.stream.snap,
r.stream.stats: move back to Addons
I would like to go ahead...
thanks,
On Fri, Oct 31, 2014 at 12:01 PM, Markus Neteler <neteler@osgeo.org> wrote:
trash all of them. d.measure and d.colors are replaced in gui, d.extract is
missing in gui but this code is useless anyway
Anna
still useful logic
more nicely now - ?
* raster/r.grow - ?
* raster/r.le - ?
thanks,
grass-dev mailing list
grass-dev@lists.osgeo.org
* raster/r.grow - ?
I'm for move to addons [1]. Do you have suggestions for the name? The
difference is that it supports negative "grow" besides the standard one.
[1] http://trac.osgeo.org/grass/ticket/2368#comment:4
On Fri, Oct 31, 2014 at 10:15 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
ok: d.colors, d.measure, d.what.rast, d.what.vect, d.zoom removed in r62508.
Will backport that then to relbr7.
r.stream.stats: moved back from relbranch7 to Addons (r62511 and
r62512).
Future fixes in trunk may be backported to Addons at this point.
On Fri, Oct 31, 2014 at 10:17 PM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
* raster/r.grow - ?
There is this open ticket
https://trac.osgeo.org/grass/ticket/2368
On Fri, Oct 31, 2014 at 5:01 PM, Markus Neteler <neteler@osgeo.org> wrote:
Update: cleanup of unused r.digit in r62515.
Yet open:
- r.bitpattern: Remove r.bitpattern since r.mapcalc+i.modis.qa does it
more nicely now - ?
- raster/r.in.arc and raster/r.out.arc (use r.in.gdal/r.out.gdal) - ?
- raster/r.in.tiff and raster/r.out.tiff (use r.in.gdal/r.out.gdal) - ?
- raster/r.grow - https://trac.osgeo.org/grass/ticket/2368 - ?
- raster/r.le (sufficiently superseded by r.li?) - ?
- raster/r.watershed/shed (last change 5 years ago!) - ?
On 1 November 2014 11:15, Markus Neteler <neteler@osgeo.org> wrote:
Yet open:
these three could be removed from my point of view!
ciao
Luca
www.lucadelu.org
