[GRASS-dev] dealing with nan
Hello,
I have some data that reads as "nan", while rare, it may happen when
compressing/uncompressing GRASS Locations to ship them across
Internet.
I would like to know how to deal with them in GRASS raster
programming, so that they are:
1 - detected
2 - set to null
thank you,
Yann
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
Internet.
1 - detected
2 - set to null
  if (x != x)
    G_set_d_null_value(&x, 1);
There is also isnan(), which is in C99, and also specified by POSIX:
  http://www.opengroup.org/onlinepubs/009695399/functions/isnan.html
However, I don't know if it exists on all platforms which we care
about. MSDN says that MSVCRT has _isnan() (with a leading underscore),
but it's defined in <float.h> rather than <math.h>.
The (x != x) test should be portable; OTOH, it's the kind of thing
that compilers often get wrong, particularly when optimising (if you
ignore NaN, x!=x is always false).
For 7.0, I intend to change G_is_[fd]_null_value() to treat all NaN
values as null, not just the specific bit patterns which it currently
uses.
2008/5/19 Glynn Clements <glynn@gclements.plus.com>:
Yann Chemin wrote:
I have some data that reads as “nan”, while rare, it may happen when
Internet.
1 - detected
2 - set to null
if (x != x)
Sounds simple enough.
However, I don’t know if it exists on all platforms which we care
but it’s defined in <float.h> rather than <math.h>.
hmm… ok
The (x != x) test should be portable; OTOH, it’s the kind of thing
OK, this is a pickle… I’ll give it a try and see what it does here.
uses.
This would be good indeed.
Yann Chemin
> rare, it may happen when compressing/uncompressing
> GRASS Locations to ship them across Internet.
what method are you using to compress/decompress?
..zip? .tar.gz? r.pack/r.unpack?
if r.pack I think it is safer to use the script in the trac wish patches which converts GRASS <=6 raster dir layout to proposed GRASS 7 $MAPSET/raster/$NAME/element) then tarball up the map's dir, and vice versa. I should probably update r.pack not to use r.{in|out}.mat as that will lose some metadata for sure.
places in the code to look for accidental creation of nan:
- (x/y) where both the x and y variables could sometimes be 0.
- tan(pi/2)
- r.in.mat/r.out.mat use Matlab's NaN to store grass NULLs
- GRASS nulls + non-core libgis functions meet mixed endian (?)
> raster programming, so that they are:
> 1 - detected
> 2 - set to null
Glynn:
  if (x != x)
by POSIX:
which we care about. MSDN says that MSVCRT has _isnan() (with a
leading underscore), but it's defined in <float.h> rather than
<math.h>.
kind of thing that compilers often get wrong, particularly when
optimising (if you ignore NaN, x!=x is always false).
there is a longstanding wish that 'r.null setnull=' could understand nan, so that you could get rid of them. e.g. very rarely r.in.xyz will create them, I am not sure why/how.
all NaN values as null, not just the specific bit patterns which
it currently uses.
the only reason I could see to keep them as nan not grass-NULL would be for debugging (there is obviously a bug if you get them..).
Hamish
2008/5/19 Hamish <hamish_b@yahoo.com>:
…zip? .tar.gz? r.pack/r.unpack?
Windows zip, ftp download across the World, then Linux unzip.
if r.pack I think it is safer to use the script in the trac wish patches which converts GRASS <=6 raster dir layout to proposed GRASS 7 $MAPSET/raster/$NAME/element) then tarball up the map’s dir, and vice versa. I should probably update r.pack not to use r.{in|out}.mat as that will lose some metadata for sure.
We will use r.[,un]pack that from now on.
  • (x/y) where both the x and y variables could sometimes be 0.
  • tan(pi/2)
  • r.in.mat/r.out.mat use Matlab’s NaN to store grass NULLs
  • GRASS nulls + non-core libgis functions meet mixed endian (?)
hmm, tan() is a suspect here. x==y==0 may also be, shall put tests but more complex.
1 - detected
2 - set to null
Glynn:
if (x != x)
by POSIX:
leading underscore), but it’s defined in <float.h> rather than
<math.h>.
there is a longstanding wish that ‘r.null setnull=’ could understand nan, so that you could get rid of them. e.g. very rarely r.in.xyz will create them, I am not sure why/how.
would be useful to make coloring of output maps appear… right now nan intefers in the standard colors setup, it seems.
it currently uses.
the only reason I could see to keep them as nan not grass-NULL would be for debugging (there is obviously a bug if you get them…).
Hamish
Yann Chemin
Hamish:
unzip.
I meant that r.pack as it is now may be lossy, and "r.convert" + "tar czf" may be a safer way:
  http://trac.osgeo.org/grass/ticket/84
(feel free to try, but be warned)
Hamish
Hamish:
unzip.
I meant that r.pack as it is now may be lossy, and “r.convert” + “tar czf” may be a safer way:
Oh! Excuse my Frenglish, ok got the point.
Hamish
Yann Chemin
- tan(pi/2)
That should be +/- Inf, not NaN. atan2(0,0) will return NaN, though.
GRASS' FP nulls are the all-ones bit patterns, which are unaffected by
endianness issues.
scanf("%f") etc understand "nan" (case not significant).
However, although "r.null ... setnull=nan" will result in a rule with
low==high==NaN, as NaN is neither less than, equal to, or greater than
itself, testing actual NaN values against that rule will always fail.
Maybe you actually have "nan"s in the file?
> it currently uses.
I'm not proposing changing G_set_[df]_null_value(), only the test. If
the test is changed, there's no reason to explicitly convert "other"
NaN values to the GRASS value (which is just one possible NaN value;
any value with an all-ones exponent and a non-zero mantissa is NaN).
