[GRASS-dev] dealing with null values in rasters only within mask
Hi to all,
As a followup of some recent discussions concerning the handling of null values, I have a fundamental issue, and would like some feedback:
I am working with irregular tiles of orthoimages. Each tile corresponds to the part of a large image mosaic that comes from a particular take.
Some of these tiles contain pixels with null values (generally due to sensor saturation).
I would like to be able to do the following:
- detect whether there are any null values in the tile
- replace the pixels values with a given value (or possibly use something like r.fill.stats)
For this, I am confronted to some issues:
- r.univar does not make a difference between null values in the data and those that are due to a mask (https://trac.osgeo.org/grass/ticket/3696). This means that if I create a mask to correspond to the irregular tile, I cannot use r.univar to detect whether there are any null values within the actual image tile.
- If I decide to just replace all null values with a given value, r.null also does not take into account the mask. IOW, it will fill all null pixels in the entire region outside the mask with that value.
- The same happens if I use r.mapcalc to replace null values with a given value.
Is there any way to solve this issues with existing tools, or would this demand a change in the code, in order to differentiate null values that are null because of a mask from other null values ? Any reflections on this ?
Moritz
Hi Moritz,
Did you consider r.stats -N for checking for NULL values within the masked area, like:
r.stats -N input=tile,MASK
if there is *|1 in the output you have NULL cells in the tile...
For filling NULLs with a given value you could do:
r.mapcalc expression=tile_filled=if(MASK,if(isnull(tile),1,tile),null())
Just an idea...
Stefan
-----Original Message-----
From: grass-dev <grass-dev-bounces@lists.osgeo.org> On Behalf Of Moritz Lennert
Sent: fredag 28. juni 2019 10:57
To: grass-dev@lists.osgeo.org
Subject: [GRASS-dev] dealing with null values in rasters only within mask
Hi to all,
Moritz
grass-dev mailing list
https://lists.osgeo.org/mailman/listinfo/grass-dev
Hi Moritz,
More generally from Stefan's answer:
1) MASK is a raster that you can use is your r.mapcalc expressions
2) A two-step process where everything is filled, and then the parts outside the mask are re-nulled?
  -k.
On 28/06/19 11:10, Stefan Blumentrath wrote:
Hi Moritz,
Nice trick, didn't actually know about the -N flag...
Duh, now that I see this, it seems quite obvious.
Thanks Stefan !
(And thanks Ken for your ideas)
Moritz
Hi Moritz,
On Fri, Jun 28, 2019 at 11:56 AM Moritz Lennert <mlennert@club.worldonline.be> wrote:
Hi Moritz,
if there is *|1 in the output you have NULL cells in the tile…
the fastest way to get the total number of cells and the number of non-NULL cells, ignoring any MASK, is r.info -s, e.g.
cells=4917486 ← total number of cells
n=4873149 ← number of non-NULL cells
these numbers are stored in metadata and independent of the current region
Nice trick, didn’t actually know about the -N flag…
in this case, I recommend to create a custom mask that is not named MASK but e.g. mymask, and the r.mapcalc expression probably needs some modification regarding NULL values in mymask:
r.mapcalc expression=“tile_filled = if(isnull(mymask) != 0 and mymask != 0, if(isnull(tile), 1, tile), null())”
The reason is that if(MASK, …) should return NULL if MASK is NULL which is not what you want, you want " if MASK is not NULL"
Markus M
Thanks Stefan !
Moritz
Hi Markus,
On 28/06/19 22:08, Markus Metz wrote:
Hi Moritz,
On Fri, Jun 28, 2019 at 11:56 AM Moritz Lennert <mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be>> wrote:
> > Hi Moritz,
the fastest way to get the total number of cells and the number of non-NULL cells, ignoring any MASK, is r.info <http://r.info> -s, e.g.
cells=4917486 <-- total number of cells
n=4873149 <-- number of non-NULL cells
But so this does not help in my problem which is to determine the number of NULL pixels within a given MASK.
r.mapcalc expression="tile_filled = if(isnull(mymask) != 0 and mymask != 0, if(isnull(tile), 1, tile), null())"
The reason is that if(MASK, ...) should return NULL if MASK is NULL which is not what you want, you want " if MASK is not NULL"
Right, thanks for the hint !
Moritz
