is there a way to set a string as the content of a default "answer" for
the G_OPT_F_INPUT option? I am trying to identify potential cases in the
grass-addons repository, but I am not sure I have seen something related.
The G_OPT_F_INPUT offers a field to enter a filename. The default
"answer", for the parser, will be the name of the file.
In addition, a field to "enter values directly" is created. The
description of this field is: "Enter file content directly instead of
specifying a file. Temporary file will be automatically created."
Can this field be filled with a pre-defined content?
The use case is to expose, to the user, a pre-defined set of
reclassification rules. These will help a beginner to get started,
understand easier and modify rules as he sees fit.
* Moritz Lennert <mlennert@club.worldonline.be> [2018-04-17 15:56:10 +0200]:
On 17/04/18 15:31, Nikos Alexandris wrote:
Dear developers,
Use the 'answer' parameter:
#% answer : myfilename
Moritz
It works: it loads the content of an external file. Are we forced to use
external files in such a case? Which means an extra file has to be
shipped with the source code.
Can we not use an in-script hardcoded string for example?
is there a way to set a string as the content of a default “answer” for
“answer”, for the parser, will be the name of the file.
In addition, a field to “enter values directly” is created. The
description of this field is: “Enter file content directly instead of
specifying a file. Temporary file will be automatically created.”
Use the ‘answer’ parameter:
Moritz
Be aware that you can’t use a hardcoded full path, because depending on the installation/user/os, that path may or may not exist. If you use a relative path, that path is relative to the current working directory which is of course not constant between sessions/installation/user/os. I’m afraid a default answer to G_OPT_F_INPUT will cause a lot of trouble.
Dear developers,
Moritz
Sure you can.
Use write_command() with stdin=text that you wish to feed into r.reclass. You can find several examples of its usage in existing scripts.
Moritz
P.S. Thanks to MarkusM for raising the point about file path difficulties...
On Tue, Apr 17, 2018 at 4:21 PM, Nikos Alexandris <nik@nikosalexandris.net>
+0200]:
>>> Dear developers,
related.
>> Moritz
Be aware that you can't use a hardcoded full path, because depending on the
course not constant between sessions/installation/user/os. I'm afraid a
my2c
Markus M
Ciao Markus.
Yet my intention was/is to use a hardcoded string of rules. Not a path to a file.
It appears the only option is to document, the rules, and suggest a copy and paste in to the corresponding field.
Can the parser be extended in this regard with yet another option? Perhaps I missed some existing option (?).
I’m sorry if my comment is out of topic as I’m not following the whole discussion, but can you just hardcode the values in the code and allow them to be overridden by the user-specified file? That is much simpler (for both user and GRASS) than handling paths and if the file is short, it does not raise major code cleanness concern. If people need to edit the file, then documentation is the appropriate place.
related.
Moritz
my2c
Markus M
Ciao Markus.
I'm sorry if my comment is out of topic as I'm not following the whole
Hi Vaclav,
I can do what you suggest. It is not, however, what I want to do.
By referring to "a string as the content of a default answer for
G_OPT_F_INPUT" I mean exactly this: the content of the answer. The answer is a
file name. It's content is a string.
Example: one want to use a GRASS GIS module, say through QGIS. If one
sees an example set of rules in the corresponding box, right away when
launching the GUI (or r.SomeModule --ui), it is easier to grasp the syntax and
successively the logic of whatever is shown.
I can't figure out a way in Python on how to set this content without
using an external file.
Would you devs think it makes sense to request, via a
ticket, an option for the parser to fill in, in addition to the existing
"answer" to G_OPT_F_INPUT (which will fill in a file name, and if the
file exists, its content will be printed in the larger box below it), an
in-script hardcoded string as the content that will be "loaded" in this
larger box?
Maybe name it "content" or "rules" or "filecontent" or something
similar?
Hi Vaclav,
larger box?
similar?
IIUC, what you would like to be able to do is to prefill the text box that you have, for example, in in the r.reclass GUI under "or enter values directly" (see attached screenshot) ?
* Moritz Lennert <mlennert@club.worldonline.be> [2018-04-18 11:13:53 +0200]:
On 18/04/18 10:50, Nikos Alexandris wrote:
Vaclav:
Hi Nikos,
Hi Vaclav,
larger box?
similar?
Correct (first post, last sentence -- apologies if it was not clear
enough). It will enable a better user-experience, the way I understand
GRASS GIS.
