I’ve added a menu option (under configure) to make it easier to set the default font for displayed text in GRASS. It works pretty well with my Mac, but it needs to be tested on other systems. Currently it tries to get you to a reasonable possibility for a directory containing your fonts. On the Mac, it goes to /Library/Fonts, on Windows, it starts at $WINDIR/fonts, on other systems, it starts at /usr/lib/x11/fonts. If one of these directories does not contain your fonts, you can browse to it. The font selection dialog will retain your settings throughout the GRASS session to make it easy to change default display fonts.
Michael
Arizona State University
I¹ve added a menu option (under configure) to make it easier to set
WRT Linux, it should be "X11", not "x11":
- /usr/lib/x11/fonts
+ /usr/lib/X11/fonts
on Debian all the TT fonts are in /usr/share/fonts [/truetype/].
/usr/lib/X11/fonts exists as a symlink to /usr/X11R6/lib/X11/fonts/,
but that only has residual symlinks, encoding info, and cache files.
Debian can/will always patch to do things the Debian way, but what's
popular with other distros these days?
I^(1)ve added a menu option (under configure) to make it easier to set
Same on Ubuntu 6.06.1 Dapper.
On Ubuntu Dapper there is no /usr/X11R6/lib/X11/fonts/. Seems that the
same content you describe is present in Ubuntu's /usr/share/X11/fonts.
In /usr/lib/X11/fonts there is a set of symlinks to subdirectories of
/usr/share/X11/fonts (100dpi, 75dpi, encodings, misc, Type1).
I¹ve added a menu option (under configure) to make it easier to set the
Note that it should be "X11" with an upper-case "X".
browse to it.
Does it handle the case where the directory doesn't exist? Gentoo
doesn't have /usr/lib/X11/fonts; fonts normally go into subdirectories
of /usr/share/fonts.
Ah yes. Capitalization is important on 'other' systems.
Michael
Hamish
Duly noted by Hamish.
browse to it.
Yes. There is a test. If the 'reasonable guess' initial directory doesn't
exist, the initdir variable is set to "", which means it starts out in the
current working directory. Once you browse to your font director and pick
something, this is set as default for the rest of the session or until you
change it.
Michael
