In the module r.walk, it seems that the default value for lambda should be 0. Is this correct? If so, can it be set as the default so that new users wouldn't constantly need to look it up and put 0 in this field?
Michael
Michael
I've been emailing with Helena to try to understand exactly how lambda and a friction surface interacts with information about topography (extracted from a DEM) in r.walk. It seems a good idea to put this back on the list. Perhaps I'm the only one a little in the dark, but maybe it can help others.
On Oct 10, 2008, at 10:40 AM, Helena Mitasova wrote:
To clarify for me, is it
total cost = (movement time cost + lambda) * friction costs
OR
total cost = movement time cost + (lambda * friction costs)
I did not look into the code but if there are no brackets in the code, this second interpretation applies.
For anyone familiar with the code, is this the case? If so, should I be thinking in time units for creating a friction map? If I remember, r.walk normally outputs in seconds to traverse the cell.
So, should the friction map be in additional seconds to traverse the cell? Or is friction a weighting factor (i.e., multiplicative rather than additive)?
Thanks
Michael
I opened the code and it has it right in header:
TOTAL COST = [(WALKING ENERGY ) + (LAMBDA*FRICTION)]
maybe this is how it should go into the man page
Helena
OR
Thanks
Michael
That seems like a good idea.
This suggests that friction and lambda should be in some kind of energy units.
However, as I understand it, the values in an r.walk map--using the default values--are an estimate of the number of seconds to traverse a cell walking 'normally' (i.e., according to the default values). Is this true anyone? If so, wouldn't the additive friction need to be in time units?
I'm not trying to be dense, but trying to get clear about what the output is actually telling us, since it does not seem to be in arbitrary units like r.cost is (unless you do some numerical massaging).
Michael
OR
Thanks
Michael
these are perfectly valid questions - authors should probably answer them rather than me
but we tried to put some explanation based on the manual in to the appendix of GRASSbook
and I have just covered it in the class so I had to spend some time trying to understand it.
the units are - according to the manual - time - see below
S, H are meters but the coefficients a,b,c,d are 1/speed which is sec/meter giving you time in seconds,
then friction map can be either in units of time (sec) and lambda is unitless weight
or friction is unitless factor and lambda is in seconds which converts it to time.
So the results are in seconds - when you derive contours from the results you will get isochrones -
so you can delineate an area where the person gets within 2 hours or whatever time you chose.
But it would be really good to hear from the authors because these are my interpretations
of the manual and my experiments with the module. The man page is pretty good it just needs to be more clear that the cost is measured by time (if I understand it correctly)
Helena
T= [(a)*(Delta S)] + [(b)*(Delta H uphill)] + [(c)*(Delta H moderate downhill)] + [(d)*(Delta H steep downhill)]
where:
T is time of movement in seconds,
Delta S is the distance covered in meters,
Delta H is the altitude difference in meter.
The a, b, c, d parameters take in account movement speed in the different conditions and are linked to:
* a: underfoot condition (a=1/walking_speed)
* b: underfoot condition and cost associated to movement uphill
* c: underfoot condition and cost associated to movement moderate downhill
* d: underfoot condition and cost associated to movement steep downhill
It has been proved that moving downhill is favourable up to a specific slope value threshold, after that it becomes unfavourable. The default slope value threshold (slope factor) is -0.2125, corresponding to tan(-12), calibrated on human behaviour (>5 and <12 degrees: moderate downhill; >12 degrees: steep downhill). The default values for a, b, c, d are those proposed by Langmuir (0.72, 6.0, 1.9998, -1.9998), based on man walking effort in standard conditions.
The lambda parameter of the linear equation combining movement and friction costs:
total cost = movement time cost + (lambda) * friction costs
must be set in the option section of r.walk.
Michael
OR
Thanks
Michael
Thanks very much for this thorough explanation Helena. It is quite helpful. I hope that Roberto can verify (or correct) this.
I'm copying some folks who have been working with r.walk recently. Our lab discussions on this caused me to raise these questions.
On the issue I first asked about, it seems that lambda should either 1) have a default value of 1 or 2) be optional.
Michael
and I have just covered it in the class so I had to spend some time trying to understand it.the units are - according to the manual - time - see below
so you can delineate an area where the person gets within 2 hours or whatever time you chose.But it would be really good to hear from the authors because these are my interpretations
of the manual and my experiments with the module. The man page is pretty good it just needs to be more clear that the cost is measured by time (if I understand it correctly)Helena
where:
Delta H is the altitude difference in meter.The a, b, c, d parameters take in account movement speed in the different conditions and are linked to:
* d: underfoot condition and cost associated to movement steep downhillIt has been proved that moving downhill is favourable up to a specific slope value threshold, after that it becomes unfavourable. The default slope value threshold (slope factor) is -0.2125, corresponding to tan(-12), calibrated on human behaviour (>5 and <12 degrees: moderate downhill; >12 degrees: steep downhill). The default values for a, b, c, d are those proposed by Langmuir (0.72, 6.0, 1.9998, -1.9998), based on man walking effort in standard conditions.
must be set in the option section of r.walk.Michael
OR
Thanks
Michael
I join Michael in this request:
http://article.gmane.org/gmane.comp.gis.grass.devel/23787
(in our case, it was looking at energy penguins expended to reach their nests)
Hamish
Several weeks back, Helena gave a very good explanation of how r.walk actually works. It makes very good sense (see below). However, from this explanation, it is clear that lambda and a friction map should be optional rather than required as they are now.
The main part of r.walk calculates the time (in seconds) needed to walk across a landscape.
For any cell,
total time = (walking time in seconds to traverse the cell given its slope) + (lambda * friction map)
Lambda is a weighting coefficient to convert the friction map to units that match the costs due to slope (i.e., units in seconds normally).
If you want to calculate walking time to traverse a landscape that is based solely on the topography (i.e., slope), then you need a friction map with a value of 0; lambda can be anything.
So this should be optional. Currently, you need to create a 0 friction map and try to figure out what lambda should be in order to run r.walk. This is sort of pointless and can cause considerable confusion.
So, can lambda and friction map be changed to optional arguments for our upcoming releases?
Thanks
Michael
Begin forwarded message:
Date: October 10, 2008 9:27:46 PM GMT-07:00
To: Helena Mitasova <hmitaso@unity.ncsu.edu>
Cc: grass developers <grass-dev@lists.osgeo.org>, Ullah Isaac <Isaac.Ullah@asu.edu>, David.Quixal@uv.es, Sean Bergin <Sean.Bergin@asu.edu>, Moreno Martín Andrea <andrea.moreno@uv.es>
Subject: Re: [GRASS-dev] default for r.walkThanks very much for this thorough explanation Helena. It is quite helpful. I hope that Roberto can verify (or correct) this.
I’m copying some folks who have been working with r.walk recently. Our lab discussions on this caused me to raise these questions.
Michael
However, as I understand it, the values in an r.walk map–using the default values–are an estimate of the number of seconds to traverse a cell walking ‘normally’ (i.e., according to the default values). Is this true anyone? If so, wouldn’t the additive friction need to be in time units?
I’m not trying to be dense, but trying to get clear about what the output is actually telling us, since it does not seem to be in arbitrary units like r.cost is (unless you do some numerical massaging).
Helena
T= [(a)(Delta S)] + [(b)(Delta H uphill)] + [(c)(Delta H moderate downhill)] + [(d)(Delta H steep downhill)]
where:
- a: underfoot condition (a=1/walking_speed)
- b: underfoot condition and cost associated to movement uphill
- c: underfoot condition and cost associated to movement moderate downhill
- d: underfoot condition and cost associated to movement steep downhill
Michael
I’ve been emailing with Helena to try to understand exactly how lambda and a friction surface interacts with information about topography (extracted from a DEM) in r.walk. It seems a good idea to put this back on the list. Perhaps I’m the only one a little in the dark, but maybe it can help others.
OR
Thanks
Michael
Not that I'm disagreeing with the need to change this functionality,
but based on the way the algorithm incorporates the friction map, you
can currently put zero for lambda and any map for the friction to have
it work on slope alone. This is a little easier than the method you
mentioned.
ie. total cost = movement time cost + (0 * friction)
Further, I believe to make lambda and friction optional will take
relatively substantial re-writes.
-Colin
On Thu, Nov 13, 2008 at 1:16 PM, Michael Barton <michael.barton@asu.edu> wrote:
explanation, it is clear that lambda and a friction map should be *optional*
rather than *required* as they are now.
across a landscape.
For any cell,
upcoming releases?
Thanks
Michael
____________
Begin forwarded message:From: Michael Barton <michael.barton@asu.edu>
I hope that Roberto can verify (or correct) this.I'm copying some folks who have been working with r.walk recently. Our lab
discussions on this caused me to raise these questions.On the issue I first asked about, it seems that lambda should either 1) have
a default value of 1 or 2) be optional.Michael
units.However, as I understand it, the values in an r.walk map--using the default
so, wouldn't the additive friction need to be in time units?I'm not trying to be dense, but trying to get clear about what the output is
r.cost is (unless you do some numerical massaging).these are perfectly valid questions - authors should probably answer them
rather than mebut we tried to put some explanation based on the manual in to the appendix
of GRASSbookand I have just covered it in the class so I had to spend some time trying
giving you time in seconds,then friction map can be either in units of time (sec) and lambda is
unitless weightor friction is unitless factor and lambda is in seconds which converts it to
time.So the results are in seconds - when you derive contours from the results
you will get isochrones -so you can delineate an area where the person gets within 2 hours or
interpretationsof the manual and my experiments with the module. The man page is pretty
downhill)] + [(d)*(Delta H steep downhill)]where:
conditions and are linked to:* a: underfoot condition (a=1/walking_speed)
standard conditions.The lambda parameter of the linear equation combining movement and friction
costs:total cost = movement time cost + (lambda) * friction costs
Michael
I'm the only one a little in the dark, but maybe it can help others.On Oct 10, 2008, at 10:40 AM, Helena Mitasova wrote:
OR
second interpretation applies.For anyone familiar with the code, is this the case? If so, should I be
normally outputs in seconds to traverse the cell.So, should the friction map be in additional seconds to traverse the cell?
additive)?Thanks
Michael
grass-dev mailing list
Hi Colin,
mentioned.
This is a handy workaround. However, it is probably better in the long run to fix this than to depend on a workaround.
Hopefully, this won't really take that much effort. However, while we're on the subject, one of my students noticed something that might take more substantial rewrites and I guess I should mention it now.
If we are correct on how r.cost uses a friction map (and this is not 100% certain), there is a fundamental flaw. A cost distance map should have cells that represent cumulative cost outward from a starting point. r.walk automatically calculates this in seconds, making it a really useful module to have in GRASS.
If the friction map is added in AFTER the initial cumulative walking time cost map is generated, the result will violate the cumulative nature of the cost map. Imagine a map generated by r.walk with a cumulative time cost along a line of cells as follows:
0 | 100 | 120 | 150 | 250 | 350 |
Now ADD a friction map to this
0 | 0 | 200 | 300 | 0 | -150 |
Here is the result
0 | 100 | 320 | 450 | 250 | 200 |
The final map is no longer the cumulative time to travel from the origin. More distant cells take less time to reach than closer cells.
The friction map needs to be incorporated into the cost along with topographic slope when the initial time map is created, not afterwards.
Michael
-Colin
across a landscape.
For any cell,
upcoming releases?
Thanks
Michael
____________
Michael
OR
additive)?Thanks
Michael
grass-dev Info Page
If I understand your comment correctly then the current r.walk
functionality is actually doing what you want it to be doing (ie.
there is no problem). r.walk does not create a full cumulative cost
map and then add the friction map, rather it combines the cumulative
cost and friction cost with each origin pixel to neighbouring pixel
calculation. If this was unclear in the help file perhaps an update to
clarify is needed.
See the snippet of code below from r.walk/main.c where "case 1"
represents the consideration of the western neighbour:
1024 switch (neighbor) {
1025 case 1:
1026 dtm_value = &W_dtm;
1027 segment_get(&dtm_in_seg, dtm_value, row, col);
1028 cost_value = &W_cost;
1029 segment_get(&cost_in_seg, cost_value, row, col);
1030 if (G_is_d_null_value(cost_value))
1031 continue;
1032 if (((W_dtm - my_dtm) / EW_fac) >= 0)
1033 fcost_dtm = (double)((double)(W_dtm - my_dtm) * b);
1034 else if (((W_dtm - my_dtm) / EW_fac) < (slope_factor))
1035 fcost_dtm = (double)((double)(W_dtm - my_dtm) * d);
1036 else
1037 fcost_dtm = (double)((double)(W_dtm - my_dtm) * c);
1038 fcost_cost = ((double)(W_cost + my_cost) / 2.0);
1039 min_cost =
1040 pres_cell->min_cost + fcost_dtm + (EW_fac * a) +
1041 lambda * fcost_cost * EW_fac;
1042 break;
The last calculation shows that the neighbour's new cost (min_cost)
will be equal to the origin's cumulative cost (pres_cell->min_cost) +
the topographic/slope cost to move to the western neighbour
(fcost_dtm) + lambda * the friction cost to move to the western
neighbour (fcost_cost).
I hope that helps and that I wasn't more long winded than was called for :).
-Colin
On Thu, Nov 13, 2008 at 2:34 PM, Michael Barton <michael.barton@asu.edu> wrote:
Hi Colin,
mentioned.This is a handy workaround. However, it is probably better in the long run
to fix this than to depend on a workaround.ie. total cost = movement time cost + (0 * friction)
relatively substantial re-writes.Hopefully, this won't really take that much effort. However, while we're on
substantial rewrites and I guess I should mention it now.If we are correct on how r.cost uses a friction map (and this is not 100%
to have in GRASS.If the friction map is added in AFTER the initial cumulative walking time
along a line of cells as follows:0 | 100 | 120 | 150 | 250 | 350 |
Here is the result
More distant cells take less time to reach than closer cells.The friction map needs to be incorporated into the cost along with
topographic slope when the initial time map is created, not afterwards.Michael
-Colin
wrote:Several weeks back, Helena gave a very good explanation of how r.walk
*optional*
across a landscape.
For any cell,
slope)
that
based
a
map
is
upcoming releases?
Thanks
Michael
____________
helpful.
lab
have
default
walking
If
is
appendix
trying
sec/meter
to
I
downhill* d: underfoot condition and cost associated to movement steep downhill
slope
value
calibrated
friction
Michael
and a
from
Perhaps
OR
this
cell?
additive)?Thanks
Michael
This is a BIG help and an equally big relief.
Now the question arises as to what kind of units should the friction map be in to make sense in this kind of calculation.
Michael
clarify is needed.See the snippet of code below from r.walk/main.c where "case 1"
represents the consideration of the western neighbour:1024 switch (neighbor) {
1025 case 1:
1031 continue;
1036 else
1039 min_cost =
1042 break;The last calculation shows that the neighbour's new cost (min_cost)
neighbour (fcost_cost).I hope that helps and that I wasn't more long winded than was called for :).
-Colin
Hi Colin,
Here is the result
-Colin
*optional*
across a landscape.
For any cell,
slope)
that
based
a
map
is
upcoming releases?
Thanks
Michael
____________
helpful.
lab
have
default
walking
If
is
appendix
trying
sec/meter
to
I
slope
value
calibrated
friction
Michael
and a
from
Perhaps
OR
this
cell?
additive)?Thanks
Michael
grass-dev Info Page
Glad to help.
While I'm at it I can try this one too. Basically, without careful
consideration, the use of a friction map will render the units of the
output relative only (ie. unitless). Which isn't necessarily a bad
thing unless you're set on knowing the actual time.
The only way to avoid this is to make sure the friction map * lambda
can logically be used to ADD time (rather than being used as a
multiplier). I can't think of a dataset that would allow you to do
this and I'm not even sure that adding the time it would take to cross
a pixel of forest to the topographic time is an accurate way of
representing multiple travel time factors. Good luck!
-Colin
Michael
1025 case 1:
1031 continue;
* b);
(slope_factor))
* d);
1036 else
* c);
1039 min_cost =
:).-Colin
wrote:Hi Colin,
run
on
cells
module
the
Here is the result
-Colin
this
*optional*
across a landscape.
For any cell,
slope)
that
based
with
a
map
This
is
our
upcoming releases?
Thanks
Michael
____________
helpful.
lab
have
default
walking
anyone?
If
output
is
like
them
appendix
trying
sec/meter
it
to
results
my
pretty
(if
I
different
slope
value
calibrated
by
friction
Michael
and a
from
Perhaps
OR
this
r.walk
cell?
additive)?Thanks
Michael
Hi Colin,
Thanks again for the info. We're looking into it. I guess we will need to do some empirical tests, but it would be nice if one could specify how to value a friction map so as to still get real time values in the output. Here seems to be the most relevant piece of code.
else
min_cost = pres_cell->min_cost + fcost_dtm + (EW_fac * a) + lambda * fcost_cost * EW_fac;
fcost_cost is not friction cost per se. Maybe my_cost is the actual friction cost value? It doesn't seem be converted to time units at that point, but this is not clear (What is W_cost?). I guess we need to know this to determine the units/value ranges for the friction map.
Possibly the easiest way to think about a friction map is as a percent of the 'normal' cost (faster or slower)--though that is not how it seems to be added in.
I'm not sure why you say a friction map would need to only ADD time. If it is included in the calculations BEFORE the final cumulative time map is made, then it could either increase OR decrease the net time to traverse a cell. This is what I was referring to a couple posts back. And this is what seems to be happening here--except that it looks like you can't really make a friction map value LESS than the topographic costs of traversing a cell. Nevertheless, it is good if we model with some factors reducing the time to cross a cell and other factors increasing the time.
Michael
____________________
C. Michael Barton
Glad to help.
in to make sense in this kind of calculation.While I'm at it I can try this one too. Basically, without careful
thing unless you're set on knowing the actual time.The only way to avoid this is to make sure the friction map * lambda
representing multiple travel time factors. Good luck!-Colin
Michael
1025 case 1:
1031 continue;
* b);
(slope_factor))
* d);
1036 else
* c);
1039 min_cost =
:).-Colin
wrote:Hi Colin,
run
on
cells
module
the
Here is the result
-Colin
this
*optional*
across a landscape.
For any cell,
slope)
that
based
with
a
map
This
is
our
upcoming releases?
Thanks
Michael
____________
helpful.
lab
have
default
walking
anyone?
If
output
is
like
them
appendix
trying
sec/meter
it
to
results
my
pretty
(if
I
different
slope
value
calibrated
by
friction
Michael
and a
from
Perhaps
OR
this
r.walk
cell?
additive)?Thanks
Michael
grass-dev Info Page
Hi again,
to be the most relevant piece of code.else
fcost_cost * EW_fac;fcost_cost is not friction cost per se. Maybe my_cost is the actual friction
Perhaps it would clarify things if I explain exactly how the two costs
(topographic and friction) are calculated and then how they're
combined. Beginning with the specified start point, an origin cell is
selected. The topographic and friction costs are then calculated to
each of its neighbours (8 or 16). The snippet of code I gave was for
the western neighbour (ie. W_cost) but it continues with every other
neighbour as well. In the code, W_dtm = the elevation cell value of
the western neighbour, W_cost = the friction cell value of the
neighbour, my_dtm = elevation of origin, my_cost = friction value of
origin.
The topographic cost is calculated by finding the difference in
elevation between the origin and its neighbour over the horizontal
resolution, dtm=digital terrain model: (W_dtm - my_dtm) / EW_fac.
Depending on the slope and the specified slope_factor it is multiplied
by one of the specified coefficients b,c,d to convert it to seconds
(see the attached graph, assuming this list will accept attachments,
nb. I converted the slope to degrees).
The friction cost is calculated by summing half the friction of each
of the origin cell and the neighbouring cell: (W_cost + my_cost) /
2.0). This is because the "walker" is travelling from cell center to
cell center and therefore only has to walk across half of each pixel
(actually in the code it is an average of the two cell values possibly
to save on calculation time). With the next step, the other half of
the pixel will be counted.
added in.
It might be convenient if it worked that way but since it is added,
rather than multiplied, I don't think the friction as a percent of
normal will work currently.
I meant the friction is ADDed as opposed to being used as a
multiplier. As you said, in theory, there is no reason why a negative
friction cost couldn't be created which would then decrease the net
time it took to cross the cell.
As for the range of the friction map to create, empirical tests are
probably the way to go. Possibly mountaineering guides would be a good
source for this kind of data as well (especially since the r.walk
equation was taken from one to begin with). Once completed, perhaps
lambda could be used for a global conversion between friction map
values and friction time (as I'm guessing it was originally intended
for this).
I hope you and your students are finding this as interesting to work
on as I have.
-Colin
Glad to help.
be
Michael
1025 case 1:
1031 continue;
my_dtm)
* b);
(slope_factor))
my_dtm)
* d);
1036 else
my_dtm)
* c);
1039 min_cost =
a)
:).-Colin
wrote:Hi Colin,
run
we're
on
100%
cells
module
time
the
Here is the result
origin.
-Colin
this
*optional*
walk
across a landscape.
For any cell,
slope)
units
that
based
with
a
friction
map
This
is
our
upcoming releases?
Thanks
Michael
____________
helpful.
Our
lab
1)
have
energy
default
walking
anyone?
If
output
is
like
them
appendix
trying
sec/meter
converts
it
to
results
are
my
pretty
(if
I
different
specific
slope
slope
value
calibrated
degrees:
by
friction
Michael
lambda
and a
(extracted
from
Perhaps
OR
code,
this
be
r.walk
cell?
additive)?Thanks
Michael
Thanks Colin,
This is all very helpful. The percentage friction map was a wish. It is clear that it can't be used that way with the current code. At least now it is very clear how lambda and a friction map interacts with the rest of the cost calculations. If some empirical tests could be made, it might be possible to suggest value ranges for a friction map that would give meaningful time values in the result. It would probably be good to get some of this information into the manual page. We will be using r.walk in a number of research settings, so we might come up with some information. If so, I'll pass it along.
Michael
______________________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
On Nov 15, 2008, at 6:06 PM, Colin Nielsen wrote:
Hi again,
determine the units/value ranges for the friction map.Perhaps it would clarify things if I explain exactly how the two costs
origin.The topographic cost is calculated by finding the difference in
nb. I converted the slope to degrees).The friction cost is calculated by summing half the friction of each
the pixel will be counted.Possibly the easiest way to think about a friction map is as a percent of
added in.It might be convenient if it worked that way but since it is added,
normal will work currently.I'm not sure why you say a friction map would need to only ADD time. If it
cross a cell and other factors increasing the time.I meant the friction is ADDed as opposed to being used as a
time it took to cross the cell.As for the range of the friction map to create, empirical tests are
for this).I hope you and your students are finding this as interesting to work
on as I have.-Colin
Glad to help.
be
Michael
1025 case 1:
1031 continue;
my_dtm)
* b);
(slope_factor))
my_dtm)
* d);
1036 else
my_dtm)
* c);
1039 min_cost =
a)
:).-Colin
wrote:Hi Colin,
run
we're
on
100%
cells
module
time
the
Here is the result
origin.
-Colin
this
*optional*
walk
across a landscape.
For any cell,
slope)
units
that
based
with
a
friction
map
This
is
our
upcoming releases?
Thanks
Michael
____________
helpful.
Our
lab
1)
have
energy
default
walking
anyone?
If
output
is
like
them
appendix
trying
sec/meter
converts
it
to
results
are
my
pretty
(if
I
different
specific
slope
slope
value
calibrated
degrees:
by
friction
Michael
lambda
and a
(extracted
from
Perhaps
OR
code,
this
be
r.walk
cell?
additive)?Thanks
Michael
grass-dev Info Page<dtm_cost.png>
