On Sep 22, 2009, at 12:28 AM, grass-dev-request@lists.osgeo.org wrote:
Date: Tue, 22 Sep 2009 08:00:36 +0200
Subject: Re: [GRASS-dev] default GUI
To: Glynn Clements <glynn@gclements.plus.com>
Cc: GRASS developers list <grass-dev@lists.osgeo.org>
Message-ID:
<f8fe65c40909212300g3e8cdf98ve17c746207ea3e9f@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1Hi,
2009/9/22 Glynn Clements <glynn@gclements.plus.com>:
What's the timescale for a 6.4.0 release? Is there enough time to
decouple the wx vdigit and nviz modules into separate programs? That
would eliminate the most likely source of major problems.I don't think that there is enough time to do that. First 6.4.0 RC
12/2008, the last (RC5) 7/2009, now we have end of September - it's
seems to me as very very long time for RC stage. I was hoping that we
could release 6.4.0 in April 2009 , then in June, ... and now in
October. To have one year for RCs seems to me as too unacceptable
time... I would be happy to see 6.4.0 out and discuss if we would be
able to change release politics (releases more often, less RCs, etc.)Initially I was not thinking about wxGUI as default for 6.4.0. Few
days ago some of devs/users started speaking about that. That's not up
me to decide, I cannot compare stability/usability of wxGUI versus
TCL/TK GUI. One of problem of the wxGUI are extensions which are not
separated from the main program (e.g. local copy of PseudoDC is used
when vector digitizer is available otherwise PseudoDC from wxPython is
used which can cause problems sometimes, etc.).Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
I agree with Martin on this. The wxPython GUI is certainly robust enough to be the default GUI for GRASS. But there are packaging and version issues that we need to solve in order to do this and not get flooded with reports of the GUI not starting or working correctly. We are close on these but not quite there.
We should fix as many outstanding bugs in the wxPython GUI as possible before a 6.4 stable release, but we should not hold up the release in order to switch default GUI's
FWIW, the TclTk GUI is also quite robust and can serve just fine for the default. The new one just does more and does it more elegantly.
Michael
______________________________
C. Michael Barton
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
