[GRASS-dev] default icon set in wxGUI
After installing the current develbranch6 SVN from scratch, wxGUI
defaulted to "grass" icon set instead of "silk". The latter is much
slicker, looks more proffessional, occupies less space. Could wxGUI
default to "silk"?
Maciek
Maciej Sieczka
www.sieczka.org
2008/8/12 Maciej Sieczka <tutey@o2.pl>:
default to "silk"?
a few days ago Michael changed default icon set to the original GRASS.
I am not sure which icon set should be default, anyway I am using
silk... Maybe we could vote?:wink:
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
default to "silk"?
+1 for silk :wink:
Martin
Martin Landa pisze:
default to "silk"?
+1 for silk :wink:
Needless to say me the same: +1 for silk.
The GRASS icon set would require couple of adjustments in the GUI layout
as it's icons are bigger (e.g. in digitizer half of the tools are not
visible unless you manually extend window width).
Maciek
Maciej Sieczka
www.sieczka.org
