Does anybody know a smart way to calculate for X rasters per raster cell the rank order of those rasters? For example, if I have three rasters X1, X2 and X3:
X1 X2 X3
1 3 2
2 5 8
5 1 3
NA 8 2
would give three new raster layers with the values:
Y1 Y2 Y3
1 3 2
1 2 3
3 1 2
NA 2 1
I am now reading the rasters in R and using a combination of apply() and rank() function to create new raster layers:
I am sure there are better ways in R, but especially when dealing with very large raster layers, I was hoping there is a way to do this directly in GRASS GIS. Or otherwise, would it be difficult to create a function for this?
X3:
X1 X2 X3
1 3 2
2 5 8
5 1 3
NA 8 2
Y1 Y2 Y3
1 3 2
1 2 3
3 1 2
NA 2 1
this?
I don't know if the result is what you are looking for but with python
I do something like this
from grass.pygrass.raster import RasterNumpy
import scipy.stats as sstats
map = RasterNumpy('YOURMAP')
map.open()
newmap = RasterNumpy('YOURNEWMAP', 'w')
newmap.open()
i = 0
for row in map:
newmap[i] = sstats.rankdata(row)
i+=1
newmap.close()
map.close()
I tested it, but when I close the map it return the error "Bus error"
Hi Luca, Thanks… I don’t know much about Python unfortunately, so it is difficult for me to see exactly what it does. I’ll try to see if I get this to work, and see if I understand the output. Cheers Paulo
On 01/23/2014 09:37 AM, Luca Delucchi wrote:
Hi Paulo
On 22 January 2014 23:20, Paulo van Breugel [<p.vanbreugel@gmail.com>](mailto:p.vanbreugel@gmail.com) wrote:
X3:
X1 X2 X3
1 3 2
2 5 8
5 1 3
NA 8 2
Y1 Y2 Y3
1 3 2
1 2 3
3 1 2
NA 2 1
in <- c("X1", "X2", "X3")
lyrs <- readRAST6(in)
tmp <- apply(lyrs@data, 1, function(x){
rank(x, na.last="keep", ties.method="average")
lyrs@data <- t(tmp)
this?
map.open()
newmap.open()
i = 0
for row in map:
i+=1
newmap.close()
map.close()
X1, X2 and X3:
X1 X2 X3
1 3 2
2 5 8
5 1 3
NA 8 2
Y1 Y2 Y3
1 3 2
1 2 3
3 1 2
NA 2 1
function for this?
I don't know how efficient this would be, but how about using r.mapcalc with something like this for each map:
X1, X2 and X3:
X1 X2 X3
1 3 2
2 5 8
5 1 3
NA 8 2
Y1 Y2 Y3
1 3 2
1 2 3
3 1 2
NA 2 1
function for this?
Y1 = if(X1>X2, if(X1>X3, 1, 2), if(X1>X3, 2, 3))
Moritz
Thanks Moritz,
I had thought about that, works good for few maps, but it gets a bit unwieldy with e.g., 40 maps. I'll try though if I can split the if function somehow.
X1, X2 and X3:
X1 X2 X3
1 3 2
2 5 8
5 1 3
NA 8 2
Y1 Y2 Y3
1 3 2
1 2 3
3 1 2
NA 2 1
function for this?
Moritz
Thanks Moritz,
function somehow.
Maybe you can find a way to script the construction of the r.mapcalc calls.
You could then launch each r.mapcalc call as a separate process to allow "parallel processing" (see i.pansharpen and others as examples).
