I’m trying to understand a change of behavior between 7.2 and trunk. With 7.2, I can do the following:
curl -SL http://fatra.cnr.ncsu.edu/foss4g2017/nc_tile_0793_016_spm.zip \
nc_tile_0793_016_spm.zip && unzip nc_tile_0793_016_spm.zip
grass72 -c EPSG:3358 ~/grassdata/crs_test -e
grass72 ~/grassdata/crs_test2/PERMANENT/ --exec r.in.lidar input=nc_tile_0793_016_spm.las output=count_10 method=n -e -n resolution=10
The last step (r.in.lidar) fails in current trunk because the projection don’t match. Here is the difference (name, datum and swapped lat_1 and lat_2):
GRASS LOCATION PROJ_INFO is:
name: NAD83(HARN) / North Carolina
datum: nad83harn
lat_1: 36.16666666666666
lat_2: 34.33333333333334
Import dataset PROJ_INFO is:
datum: nad83
lat_1: 34.33333333333334
lat_2: 36.16666666666666
7.2 considers this OK while trunk considers this different. I’m not sure which one is correct.
Here is the lasinfo reference:
PROJCS[“NAD_1983_StatePlane_North_Carolina_FIPS_3200”,
GEOGCS[“GCS_North_American_1983”,
DATUM[“North_American_Datum_1983”,
SPHEROID[“GRS_1980”,6378137,298.257222101]],
PRIMEM[“Greenwich”,0],
UNIT[“Degree”,0.0174532925199432955]],
PROJECTION[“Lambert_Conformal_Conic_2SP”],
PARAMETER[“False_Easting”,609601.22],
PARAMETER[“False_Northing”,0],
PARAMETER[“Central_Meridian”,-79],
PARAMETER[“Standard_Parallel_1”,34.33333333333334],
PARAMETER[“Standard_Parallel_2”,36.16666666666666],
PARAMETER[“Latitude_Of_Origin”,33.75],
UNIT[“Meter”,1]]
r.in.lidar -p
in both 7.2 and trunk gives:
+proj=lcc +lat_1=34.33333333333334 +lat_2=36.16666666666666 +lat_0=33.75 +lon_0=-79 +x_0=609601.22 +y_0=0 +datum=NAD83 +units=m +no_defs
g.proj -p
gives the following in 7.2 and trunk in locations created by 7.2 and trunk:
-PROJ_INFO-------------------------------------------------
name : NAD83(HARN) / North Carolina
datum : nad83harn
ellps : grs80
proj : lcc
lat_1 : 36.16666666666666
lat_2 : 34.33333333333334
lat_0 : 33.75
lon_0 : -79
x_0 : 609601.22
y_0 : 0
no_defs : defined
-PROJ_EPSG-------------------------------------------------
epsg : 3358
-PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1
I don’t know how to resolve it besides using -o but I don’t know how to justify it and why there is a difference (I don’t see it in the recent proj-related commits).
Thank you,
Vaclav
