[GRASS-dev] digitize toolbar error
Rashad
----- Forwarded Message ----
To: grass-dev@lists.osgeo.org
Sent: Thu, June 17, 2010 8:53:22 PM
Subject: digitize toolbar error
I already send a mail regarding digitization tool error and didnt recieve any response
so I am sending this mail again.
When selecting “digitize” from mapdisplay window toolbars combobox
and select a new vector map and given a name for newVectorMap
I am getting this error
Unable to initialize display driver of vector digitizer. See ‘Command output’ for details.
Reason: message=_("Unable to initialize display driver of vector "
File “/usr/local/grass-6.5.svn/etc/wxpython/gui_modules/toolbars.py”, line 1130, in StartEditing
DigitError:
what i am missing.
Rashad
I'm not sure, but probably the problem is connected with the version of
swig you are using on compiling. I use swig version 1.3.36 and don't
have problems with wxpython gui vector digitizer.
Luís
On Dom, 2010-06-20 at 01:26 -0700, Mohammed Rashad wrote:
Rashad
When selecting "digitize" from mapdisplay window toolbars combobox
Unable to initialize display driver of vector digitizer. See 'Command
output' for details.
  File
"/usr/local/grass-6.5.svn/etc/wxpython/gui_modules/toolbars.py", line
DigitError: <unprintable DigitError object>
what i am missing.
Rashad
grass-dev mailing list
2010/6/20 Luís Ferreira <lferreira75.1@gmail.com>:
probably yes. Anyway the vector digitizer should be converted to
Python using ctypes interface, I hope to have to enough time to do it
later in the summer.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Martin Landa wrote:
2010/6/20 Luís Ferreira &lt;lferreira75.1@gmail.com&gt;:
Martin
I've recently finished compiling 6.4.1 on a SL 6.1 system (64bit). Swig is
at:
GRASS 6.4.1 (ITM):~ > rpm -qa | grep swig
swig-1.3.40-5.el6.x86_64
and when I try to digitize with the wxGUI digitizer I still get the error :
Any progress on this?
Micha
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fw-digitize-toolbar-error-tp5200501p6702398.html
2011/8/19 Micha Silver <Micha@arava.co.il>:
at:
yes, in 6.4.2 digitizer has been rewritten to Python using ctypes. Try
this version.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
On Fri, 2011-08-19 at 10:53 +0200, Martin Landa wrote:
> at:
this version.
Great. I will bump up to 6.4.2.
Thanks again.
Martin
