[GRASS-dev] Direct link from GRASS to R via C
Hi
I posted on my blog an outline of an idea of how spatial data could be
easily loaded from GRASS into R and written back.
(see http://rmkrug.wordpress.com/2013/07/15/grassrlink-1/)
In a nutshell, the idea would be to use the C functions in GRASS to
write a function which returns a single column, column range or whole
raster. This function could then be called from R (via Rcpp) to get the
data into R without having to worry about intermittent exports and
imports via the hdd.
I would ike to have some input from the GRASS developer community what
they think about such a function. This function should be usable as
"stand alone", and not requiring the opening and buffer allocations et
al as in the r.example, but rather simply take the mapset, raster name,
column(s) to read, if MASK should be respected, ... arguments.
I was thinking that it would be useful to have such a function in GRASS,
as the compilation together with GRASS, in the same line as a module,
would be quite easy.
Initially, I was thinking about read and write support for rasters,
which then could be extended to vectors and 3d-rasters and possibly even
the temporal data.
Could you give feedback on what y9ou think about the idea, and how you
think it could be realized (simplicity to install would be important).
Cheers and thanks,
Rainer
Rainer M. Krug
email: RMKrug<at>gmail<dot>com
you probably know, I've once started the discussion on this topic on
grass-stats ML (very simple test code included) [1]. And I've also
tried some basic example and experienced some problems [2]. To the
information you provided I would add that the new functionality have
to be written in C++ since Rcpp is only for C++.
Vaclav
[1] http://lists.osgeo.org/pipermail/grass-stats/2012-July/001422.html
[2] http://lists.r-forge.r-project.org/pipermail/rcpp-devel/2012-July/004055.html
On 15 July 2013 17:30, Rainer M Krug <Rainer@krugs.de> wrote:
The following message is a courtesy copy of an article
that has been posted to gmane.comp.gis.grass.devel as well.
Hi
the temporal data.
Cheers and thanks,
Rainer
Rainer M. Krug
grass-dev mailing list
grass-dev@lists.osgeo.org
Vaclav Petras <wenzeslaus@gmail.com> writes:
To my shame, I must say I overlooked your threads. I am aware of the
problem which Roger discussed, therefore I think it would be the best to
write a function in GRASS which is exported and is doing the access and
simply returns the column / block / complete raster (i.e. a *very basic*
exported raster access api for grass).
This function could be called then from Rcpp and it would be much easier
then writing the complete access function in Rcpp (as you mention below,
I also think that the header files locations might be a problem).
To the
I am always confused by these two and how they are linked together - can
I use C libraries from Rcpp, as described above?
As you already have done some work (could you please mail it to me as I
can't access the attachment via gmane?), I would very much appreciate
your input - also my C / C++ experience is quite limited and input from
that side would be brilliant.
Rainer
Vaclav
Hi
the temporal data.
Cheers and thanks,
Rainer
Rainer M. Krug
Rainer M. Krug
To the
Yes you can, see my example. Generally, you can call C functions from
C++ code and create C wrapper for your C++ library (you can find
documentation everywhere, note especially the extern "C" declaration).
I have only that small example (attached) but it contains all you
need, however there were also some problems [2].
Rainer
Vaclav
Hi
the temporal data.
Cheers and thanks,
Rainer
Rainer M. Krug
Rainer M. Krug
(attachments)
test_rgrass.R (1.32 KB)
To the
Thanks - I'll look into it.
Thanks - that looks interesting (and easier then I thought, judging from
the r.example included in GRASS). I will look at it in detail and come
back to you if I have any questions.
Rainer
Rainer
Vaclav
Hi
the temporal data.
Cheers and thanks,
Rainer
Rainer M. Krug
Rainer M. Krug
<#secure method=pgpmime mode=sign>
Rainer M. Krug
