Hello,
When creating a new location from an existing georeferenced file in the startup screen, the new location does not contain the file that was used. I find this a bit counterintuitive.
How complicated would it be to import it direclty during the procedure instead of forcing the user to import it from the newly created location ? If it is too complicated, we should at least give the user the info that the file was not imported and needs to be with r.in.gdal or v.in.ogr (should be possible to tell which).
Moritz
